i wanna run some neg camber on my KE55 Corolla
but as i have found i can't use camber tops as the strut tops are to close to the strut tower
and i can't bend the struts as my ma61 rims are rather close to the strut
i found a thing on lengths from other cars
what do people run and recommend?
Model - Length - CT Dia
RA40 - 300mm - 12mm
TA22 - 300mm - 12mm
AE86 - 300mm - 12mm
KE55 - 300mm - 12mm
KE70 - 290mm - 12mm
XT130 - 310mm - 12mm (RT132 too?)
MX73 - 304mm -12mm
MX62 - 365mm - 12mm
GE Sigma - 330mm - 12mm
S13 - 350mm - 14mm
also what is involved in fitting these, esp the S13 ones?
Yeah I fitted some from a Sigma to my KE-30 2 door.
It has a ridiculous amount of camber! It looks fairly extreme, but it actually drives far better like that. Even feels more planted in a straight line too. If you go that way, you will need the Sigma ball joints too. I also had to grind the bushings on the LCA a little bit, but nothing drastic.
Unfortunately this has left me with a fair bit of toe. Does anyone know the name of the part you screw out to adjust the toe angle? I need longer one's if that's possible. Any advice would be much appreciated!
Thanks
i got gh sigmas in my ke55, gives a tough stance, nothing to major but still what i aimed for
Thanks
yes i found this with mine, toe is a bit excessive but its needed with the camber n handles way better
i put sigmas in mine, got the wheel alignment and i think there was around -2.2degrees, it has a noticeable stance but as K&S says it handles heaps better, wind a die nut down your castor rods and off you go. Its not overly difficult, i had to grind down the lca bushes and filed the taper on the ball joints. would definately recommend doing it to upgrade the handling
http://www.reocities.com/colosseum/4883/ and check out handling mods johnnys the man
Use ke70 struts. The springs are narrower, that way you'll be able to run camber tops.
Yeah AE86 and *E7* are the same because the AE86dc guys also use KE30/55/XT130 upgrade.
tc-rolla: yeah that will fit together fine just get KE30/55 ones if you want to save money as they are the same.
Why'd you have to go and say that for :P
Now the ke3x/5x arms are going to go through the roof :lol:
