3K Connversion
Hi guys hope ur doing good . I have a 3k engine and i whould like to know if i can put a damp valve on that stock 3k engine .
do you mean blow off valve?
Its blow off valve yes this is what i mean pls help .
Edited by young j
Simple answer is no. Blow off valve works between the outlet side of the turbo compressor to the intake manifold and is designed to relieve pressure when the inlet manifold butterfly is closed to help prevent pressure build up still being forced from the turbo. You have nothing there if it is a stock 3k. You would need to run a turbo manifold from your exhaust system thru a j pipe or custom manifold, a pipe from your turbo to carby or another style of intake, box it to handle the pressure and a fuel system to suit. Have a look on here theres plenty of k series turbo builds
install it on the exhaust. make a valve on the exhaust controlled by a solenoid so when you back off the valve blocks the exhaust off.
There are electronic "damp valves" as such... take your pick for your own amusement...
Edited by styler
"Damp Valve"!,shove a wet rag under the rocker cover,that'll keep it damp!
