Viterbo Posted April 30, 2016 Report Share Posted April 30, 2016 My 5K has been making a weird noise. Recently I had to reground my crank, fitted new oversized bearings. The engine made a weird noise before I do this and keep doing it right after the first startup after the work done on the crank. I thought it was bearing related but since he kept doing it, I don't know what that is. I recorded the sound on video, the car only made 150kms after the work, so I hardly believe it's bearing noise, since I tighten all bolts with the correct torque, lubrificated both crank and bearings before fitting... The sound is stronger when cold and almost inaudible when hot. I was told it can be the timing chain... So here is the video I recorded: Quote Link to comment Share on other sites More sharing options...
corollaart Posted April 30, 2016 Report Share Posted April 30, 2016 (edited) It sure is noisey,you say the noise goes out as it heats up . Timing chain ,may have a weak tensioner or chain is streched . What else was done to engine? Oil pressure ok?hydralic lifters. Changed or checked pistons rings?compression test. I would take the oil filter off and cut it open to check for metal in the paper. Just some simple stuff to check first. rob Edited April 30, 2016 by corollaart Quote Link to comment Share on other sites More sharing options...
Viterbo Posted April 30, 2016 Author Report Share Posted April 30, 2016 Nothing else was done. In november I started taking the crank out. Regrounded and new bearings. After that I had some electrical and fuel problems and it kept the car in house until yesterday when I got a new carb and was able to go make the mandatory annual inspection and the car run pretty fine. I decided to replace the oil and filter and let the car dripping during the night. Today I installed an OEM Oil Filter and Shell Helix H7 10W40 oil, around 3,5L. After I started it that noise came up. Compression is pretty good, above 12bar in all cylinders (yes, 12 bar!). I was having oil pressure problems before but since I done this work the light never came up. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted April 30, 2016 Report Share Posted April 30, 2016 I can't use Youtube with my pathetic Telstra 256K, but an important question would be- Did you take the pistons out? A broken ring or a cracked piston would make a rattley noise that quietens down as the piston heats up and expands faster than the steel block. If they finally fix my net next week I will check the video. Quote Link to comment Share on other sites More sharing options...
Viterbo Posted April 30, 2016 Author Report Share Posted April 30, 2016 No I didn't! Quote Link to comment Share on other sites More sharing options...
parrot Posted May 1, 2016 Report Share Posted May 1, 2016 I'd be replacing the timing chain and tensioner. Really should have done this when you did the crank, but not too hard to do with the engine in place. Quote Link to comment Share on other sites More sharing options...
Viterbo Posted May 1, 2016 Author Report Share Posted May 1, 2016 It's very hard to find a kit here! Would a double row be better or is it just an increase of mass to move? Quote Link to comment Share on other sites More sharing options...
bruce Posted May 1, 2016 Report Share Posted May 1, 2016 Double row timing chain would be better. Stretch less over time. Quote Link to comment Share on other sites More sharing options...
Coolrollin Posted May 1, 2016 Report Share Posted May 1, 2016 I'd check the oil pickup is no hitting the crank. Pickup could be bent. Its a crank speed noise not a cam speed noise, meaning bottom end. Quote Link to comment Share on other sites More sharing options...
Banjo Posted May 1, 2016 Report Share Posted May 1, 2016 (edited) I've listened to it 3 or 4 times, with headphones on, and it has that hollow ringing sound, associated with the noise being generated within the sump area. I presume you have checked your oil pressure ? You could possibly narrow the point of generation, a bit more, by using a mechanics stethoscope. If you haven't got access to one of these, then you can always use a piece of hose or tube, with a bolt jammed in sensing end, and the other end in your ear with the second ear blocked. Move it around the engine until you find the area with the loudest output. Whatever the result, it probable means the 5K has got to come out again, but if you can narrow it down, whilst it is running, it should make it easier to find, once the 5K is on the "operating table". You didn't by any chance change the clutch pressure plate ? I once fitted a pressure plate to a 5K, with a high pitched ticking noise whilst running. Proved to be an aftermarket India pressure plate that was a little too big in the frame, which just touched the inside of the bellhousing, at one spot. Luckily, that only required removal of the gearbox. Cheers Banjo Edited May 1, 2016 by Banjo Quote Link to comment Share on other sites More sharing options...
parrot Posted May 1, 2016 Report Share Posted May 1, 2016 http://www.ebay.com.au/itm/TOYOTA-COROLLA-3K-3KC-DOUBLE-ROW-TIMING-CHAIN-KIT-with-GEARS-NEW-/331584231981?hash=item4d33f5da2d:g:dKEAAOSwBLlVcTDR Quote Link to comment Share on other sites More sharing options...
Viterbo Posted May 1, 2016 Author Report Share Posted May 1, 2016 (edited) I found a doctors stethoscope in the house, would that sensor be too much? Do you think it can have spun a bearing?? Edited May 1, 2016 by Viterbo Quote Link to comment Share on other sites More sharing options...
Banjo Posted May 2, 2016 Report Share Posted May 2, 2016 (edited) Try it & see. I would image it will be very loud, as a doctors stethoscope is very sensitive. http://toolmonger.co...2/stethoscopes/ Cheers Banjo Edited May 2, 2016 by Banjo Quote Link to comment Share on other sites More sharing options...
Viterbo Posted May 3, 2016 Author Report Share Posted May 3, 2016 A friend that works at a Bosch Car Service shop (jokes apart hehe) came by and he thinks it's a piston knock, either by gap in the pin or side gap of the piston. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted May 4, 2016 Report Share Posted May 4, 2016 So if you take the plugs out and turn it to a few mm past top dead centre you could put a piece of dowell wood in the plug hole and see if you can push the piston down. If you find one piston with more movement than the other three you know its a damaged small end. It will only be a mm or less, more than that would be even noisier! The sexy test would be to mount a dial gauge down the plug hole and measure at now many degrees each piston moves downwards. If you don't find a bad piston you can't eliminate them, but it may be something else as well.. Quote Link to comment Share on other sites More sharing options...
