November 11, 20187 yr comment_715880 I have a 1985 KP36. I've made a lot of mods on it mainly on the mechanical part. 1. Changed the stock 2K for a 4K motor (Brand new cylinder block) 2. Put a Weber DGV 32/36 3. Switched the T40 gearbox with a T50. 4. Put new Headers and new Radiator with a low temp racing thermostat. All these are great. The problem I have is on the freeway. My Differential is a stock KP36 (picture attached) one with a ratio of 43:10 (4.3) so travelling long distance is a pain and hard to reach top speeds. I need to get me a 3.9 ratio differential in so I will be able to cruise at 100-130 KMH with the engine at low RPMs. Is there a way I can only switch my Final Diff Gears without removing my entire rear axle? Any suggestions ??? Report
November 12, 20187 yr Author comment_715886 3 hours ago, coln72 said: Can you run a taller wheel/tyre combo....? No. The factory tire settings were 165/65/12. The ones I have are 175/70/13 with extra 8 mm spacers in order for the front tires to not touch the shock absorbers. At the rear when I get some extra weight in, the tires escape the wheel arches just a few millimeters. So taller tires are not an option. Report
November 12, 20187 yr comment_715890 Its a jap style diff so you can remove axles, then the centre, and put a complete taller ratio centre in if you like. Or you can remove the one you have and have different gears fitted to it if you can find them. Report
November 13, 20187 yr Author comment_715894 I am not familiar with how many diffs there are out there, if I were to buy this one which seems to be the only one available, would it fit? https://www.ebay.co.uk/itm/Toyota-corolla-AE86-t18-4age-m-t-T-series-diff-gears-3-7-ratio/263714728652 Report
November 13, 20187 yr comment_715897 The link is for T series diff gears. They are 6.7 inches. The KP diff is 6 inches. Report
November 14, 20187 yr comment_715898 Hi Michalis, Off memory, the JAP 4.31:1 ratio diff was fitted to Corollas with auto transmission. Manual transmission models, were often fitted with 4.11:1 ratio diffs. The 3.89:1 ratio diffs were not fitted to any Corollas as standard, from memory. However, I am led to believe, that the Datsun 1200 & 120Y series, used the 3.89:1 ratio diffs, of the same origin as Toyota, & that if you can get hold of a 3.89:1 crown wheel & pinion set new, a good diff reconditioning company should be able to swap them over, & lap them in for you. A lot od Datsun 1200 utes had 3.89:1 ratio diffs. Others on this forum may be able to confirm or correct my thoughts, as I haven't actually done it myself, but I do have it on my "bucket list", as I have a KE30 with a 1.43:1 ration diff in it, that I would love to fit a 1.389:1 diff into it. Here is a listing I found, that has a number of 3.89:1 & 3.9:1 ratio diffs http://www.difflap.com.au/ratios/gearratios_ad.htm Cheers Banjo Edited November 14, 20187 yr by Banjo Report
