Teddy Posted June 1, 2006 Report Share Posted June 1, 2006 ahahah sweet :P Quote Link to comment Share on other sites More sharing options...
Clown Posted June 2, 2006 Report Share Posted June 2, 2006 I was/am still thinking of ca18det aswell. Quote Link to comment Share on other sites More sharing options...
r47107 Posted June 14, 2006 Author Report Share Posted June 14, 2006 Haha just an up-date Manage to dismantle the halfcut, check this out :thumbsup: I'm gonna miss my 4K motor but what to do, life goes on , Quote Link to comment Share on other sites More sharing options...
Rolla__Boy Posted June 14, 2006 Report Share Posted June 14, 2006 I think you will miss your 4K for about 18 seconds once the CA roars to life in that amazing KE70 body :thumbsup: Quote Link to comment Share on other sites More sharing options...
r47107 Posted June 14, 2006 Author Report Share Posted June 14, 2006 Prediction : You will miss the 4K-C the second time you replace the spun bottom end bearings :thumbsup: Bottom end bearing. which one be more specific nick. I heard that CA18 got really good engine but the internal bearing not last long, how come? Quote Link to comment Share on other sites More sharing options...
ca18rolla Posted June 14, 2006 Report Share Posted June 14, 2006 Good oil and good filter check the oil weekly like you should with any car and don't rev the tits of it and it should be sweet. Most of these motors are ten years old+ so thats why they normally spin bearings or are reved too hard. it go in the ke70 no worries just modify engine cross member brackets and make custom gearbox x/member. As for the shaft you talk about. I think you mean the tailshaft take the front yoke from the back of the gearbox and your old tailshaft and go to a drive shaft shop and they ll use them to make a new one piece number. they ll tell you where to measure from so they can make it the right lenght (normally diff flange to seal face on the g/box and and diff flange to end of the spline on g/box) Goodluck keep us posted!! Quote Link to comment Share on other sites More sharing options...
Rolla__Boy Posted June 15, 2006 Report Share Posted June 15, 2006 Nick just hates all engines Quote Link to comment Share on other sites More sharing options...
Felix Posted June 15, 2006 Report Share Posted June 15, 2006 unless it's a 4age. baaa! Quote Link to comment Share on other sites More sharing options...
r47107 Posted June 15, 2006 Author Report Share Posted June 15, 2006 Thanks guys for the advises. apreciate that. Today the motor has been lower down into the new body, will post the picture later. Quote Link to comment Share on other sites More sharing options...
DRFT_ROLLA Posted June 15, 2006 Report Share Posted June 15, 2006 BRO THATS HOT I'm BUILDING A DRIFT ROLLA TOO WHERE ARE YOU LOCATED Quote Link to comment Share on other sites More sharing options...
Biggo Posted June 17, 2006 Report Share Posted June 17, 2006 Got updates mate? this is on conversions I'm actaully hanging to see even if its using left over scrap metal from taiwan :jealous: Quote Link to comment Share on other sites More sharing options...
Falken_KE30 Posted June 17, 2006 Report Share Posted June 17, 2006 1, that car is hot, and the CA should go heaps good in it, good luck. 2, WHY IS TYPING IN CAPS SO WRONG?? seriously, atleast his post was easy to read, unlike all that short crap that you have to read 10 times just to make sence..! Quote Link to comment Share on other sites More sharing options...
r47107 Posted June 19, 2006 Author Report Share Posted June 19, 2006 Up-date now the engine has been taked out for rebuild :lolcry: . The GB is now waiting for the new clutch set. Damn quite hard to find the clutch set for CA :) . Do u guys know what the part no. or any compatible marque can be used? The engine now is ready for rebuild and check, parts that still can be used will be use due to budget constraint. Onli the leaking seals will be replace :lolcry: . The picture will be available tomorrow, promise. Quote Link to comment Share on other sites More sharing options...
Biggo Posted June 19, 2006 Report Share Posted June 19, 2006 Over hear in australia, exedy/daikin are a common clutch brand. Or if you got the $$ OS Geikin are the bomb. Other than that you can go custom or even reface the original. I recommend replacing the bottom end bearings :) and new rings/gaskets/seal etc. Just to be safe, besides its cheap insureance. Quote Link to comment Share on other sites More sharing options...
r47107 Posted June 19, 2006 Author Report Share Posted June 19, 2006 Below are the pictures: GB, dismantle and waiting for the clutch kit :) The engine Aircond compressor, look goods, Previous leaking water pump, look the rust :lolcry: Quote Link to comment Share on other sites More sharing options...
