  • Replies 31
nah its far from stock its fully reconditioned 60 thou over big stick double vaulve springs port n polish..nah its not worth running an intercooler with 4 psi maybe later i wanna decompress it with like around 10psi or sumthing
it set me back $550 with electric fuel pump i got it off rolla boi he had it on his 5k.. but i had to get it tuned and other tune ups wich cost me around $300 but it had to be done
i have seen your car before mate, looks coll with the rebel wheels, i wish i had some rebels, sounds like it goes allright for a 4k, is you angine fan held in by string on the front????, just looks like it is?
james
ive talked to rolla boy about this before, you should be getting more than 4 psi, on both the 4k ive supercharged with a SC12 i was getting 10-12 psi the the throttlebody after the blower and i get 9-10psi the the throttle body before the blower, the last setup is on a 4k with 40 thou over flat top pistons and not decompressed, only diffrence is they are both EFI and i know thats not the reason, the only other thing is maybe you guys are using bigger cams with too much overlap.
