Not bad. It'll be interesting to compare figures when I get around to converting my 4A-GZE to turbo. Are you considering running more boost through the GT28RS, or will you be waiting until you drop the compression on the SR20DE a tad? How much compression is it running?
Why is that so surprising? Is the SR20DE really that much weaker than the SR20DET? If you're just thinking it'll blow because of a relatively high static compression ratio of 9.5:1 and 10psi of boost, I can't see it happening (if the engine is anywhere near as strong as an SR20DET). Hell, VW use 10.5:1 compression on the Golf GTi motor, although I don't know how much boost they run. However, I know that tuners have successfully upped the boost and haven't had any issues. 9.5:1 compression and 10psi seems perfectly reasonable to me.
It'd be more of a piston issue and lack of oil squirters that would cause the engine to go bye bye's is what I think would be the cause of running boost on an engine that didnt come out of the factory with a turbo slapped on the side.
Yeh, i am building a forged/ h-beam bottom end, so the 28rs will cop 18 pound once that is done. My goal is a reliable 300rwhp so i may have to upgrade from the rs if it runs out of huff. I dare say you would pull similar grunt from the 4a on the same boost, just alot more lag,it would be good to compare.
I doubt the lack of oil squirters is a problem, how many factory turbo motors do you know of that even have oil squirters?? From what ive seen the srde has very little difference from the det, besides the famous oil squirters, it is only the pistons that change, admittedly the det has much heavier and thicker slugs, but this will only be needed if the motor pings or runs lean,which it aint. :D
Most factory turbo motors have oil squirters I believe... 3SGTE, RBs (bar the 30?), JZ engines etc. Could be wrong however!
I remeber reading about some an SR20DE+T in a magazine a while ago, and it was much nicer to drive because of the high comp ratio and pulled an easy 200rwkw with a fair bit of torque! I'll try dig up the article, no idea what mag it was in though :D
I had planned on using the GT28RS too, but have now got a standard GTR turbo lined up. I'll be running up to 14psi with that turbo and am hoping to get as much as 180rwkw. When I stroke the motor and get a new turbo (possibly a GT28RS), I'll only be aiming for about 340-350hp at the engine as I'll have to have an air restrictor in preparation for going into Improved Production racing. That'll be about 190-200rwkw (255-275rwhp).
Edited by ancullen
A GTR T28 is a fair bit smaller than SR T28s (Even smaller than T25 and T25Gs). Theyre also ceramic turbine so 14psi to a gentle 16psi is all you'll get out of them. I guess it'll spool pretty quick :D What motors that on ancullen?
It will be going on my 4A-GZE (eventually). I did think 20psi sounded a bit high (I'd heard about the issues with the ceramic turbine). Didn't realise the GTR version was smaller than even a T25 though. I've got a bad feeling about this now.
It's not that I want a really big turbo, but I thought the T28 might have just been small for a T28, but larger than a T25. Doesn't really matter anyway, I'll just get it put on, setup, see how much it makes, then work out what turbo will best suit my application later on.
