the largest T28 is off the gtir or s15, i think they even have .86 housings, i can't find the book now, so correct me if I'm wrong.
GTiR is the biggest. S15 is only a 0.64 exhaust A/R.
I would strongly advise against the GTR turbo because when you upgrade (and you will) youre gonna find its less compatable with the rest of the T25 flanged range of turbos. GTRs have studs on the turbo instead of the manifold and use a different dump pipe flange design. If you just want to get it up and running, grab a $200-300 T25/T25G off a CA18/SR20 and use that as your base. From there you can upgrade a little bit (T28 ~300hp or GT28RS 350hp) or alot (GT3076R ...500hp) keeping the same setup, internally gated.
Oh shit. I figured all T28's and T25's mounted the same way. I didn't realise there would be anything any different. So this T28 won't bolt on to the standard manifold on an SR20DET-powered 180 will it? And when I want to upgrade I'll have to change to. I might have to cancel the deal.
Not without modifications. It'd be a pretty silly mod to do anyway...hasnt seemed to stop a few people trying.
mmmmmmmmmm......gt3076R, if only i was rich and famous! :D
