Leaderboard
Popular Content
Showing content with the highest reputation on 05/24/17 in all areas
  1. You guys sound all grown up. Houses children jobs. Thats where I was 20 ish years ago. Its the circle of life here I am back working on cars again. This time they aren't even mine.
  2. I've got a new generation of rollaclub coming too ;) Sept 30 for us. Car looks great mate, one of these days ill have another go at aftermarket ecu in the beema, and ill be sure to come around and pick your brain. I just put some narva +50 bulbs in my wifes Forester, certainly a nice improvement for the money.
  3. Hi Ben, Dave's suggestion is excellent, as having the genuine Toyota "Yellow Bible" on the K Series, is probably one of the best investments you'll ever make, if you are going to play with a K series engine. I got one early in my journey, which covers 2K to 5K-C, and it has been invaluable. Most functions of reassembling a K Series engine are straight forward, simple, & logical, but fitting the timing chain, & aligning the crankshaft & camshaft sprockets, is one area, where if you get it wrong, it can prove dissasterous, & cause a lot of frustration, after the engine is assembled & ready to test for the first time. By that time the engine is probably already back in the engine bay, & all hooked up. The alignment is critical, & is covered in the "Yellow Bible" & the Haynes/Gregorys manuals. Essentially the timing is carried out with the engine at TDC on no: 1 & 4 cylinder. The crankshaft sprocket should be fitted first to the crankshaft, with its key fitted. The crankshaft should then be turned slightly, if required, until the "dot" marking on the outer of the crankshaft sprocket is on the lower side of the engine, and is in line with an imaginary line passing through the centre point of both crankshaft & camshaft. (see diagram in pictures below) The camshaft is then rotated, without its sprocket until the locating pin for the sprocket, lines up with inner mark on camshaft retaining plate, which again, are all in line with the imaginary line, passing through the centre points of both camshaft & crankshaft. This is now the critical point. The camshaft & crankshaft cannot be allowed to move, whilst fitting the chain. With both sprockets on a flat surface, off the engine, fit the chain to both sprockets, such that when you pick up both sprockets & chain, that they slide onto the keyway (crankshaft) & locating pin (camshaft) without rotationally moving either sprocket. When fitted, a straight edge, (like a steel ruler) should line up with both outer sprocket marks & the centre points of both crankshaft & camshaft. Actually much simpler than it sounds, when you describe it, but it is important, because if the chain is out one or two links, then the engines valve & distributor timing will be out dramatically. Have a look at the relevant scans from the manuals below, & it should all gell, as "a picture paints a thousand words". P.S. The manuals refer to markings on the chain, which I've never been able to find, because the chains are old & discoloured. Whilst laying the sprockets on a flat surface, with a straight though the centre point of both sprockets, & sprocket markings, I've just put a dab on "white Out" on the relevant link at each end to assist. Good luck, & let us know how you go. Cheers Banjo
  4. 1 point
    I'm all for the 'ol oil and crank. It might come good, it might not, but its easy to do and it worked for Dave. Its a Toyota after all. This kind of crap is why we love em. $5 says it comes good, the motor maybe sat for years by the sounds... Oh and I have a second comp tester if you want to verify.
  5. 1 point
    Do the full throttle bit- You want the maximum air jammed in the cylinder & the highest rpm you can get. About 5 turns will do it, but the guy holding the comp gauge will see it tail off. Make sure the rubber bung on the gauge doesn't leak, the screw-in ones are more time-consuming but better.
