mrduke
Everything posted by mrduke
  1. i think they have the coil built in distributor. easy way is there a coil lead coming out of dizzy cap?
  2. if ya got a manual speedo cable in ya pile of bits i'll have it,my car was originally auto so didn't work with 5 speed. and guys,next year we can watch other makes takin it to the v8 supertaxis. hear nissan has already signed drivers and chrysler is keen too. v8 aurion??? :yes:
  3. nah,it's ok. one of my outlets cracked when doin my conversion. might just put a new one in eventually. pretty low on the list of things to do to mine...
  4. other option would be to just buy something already engine converted(not necesarily 4age). could get something regoed to use as daily as well. have seen one with 4agze for $8000 and 4age's for as little as $3500. worth lookin around. and if ya ripping all that a/c dash stuff out can i have the heater core if it's any good? mine leaks... :)
  5. 4age conversion is very easy,i did mine over easter last year. first motor wasn't so good but got another front cut for $400. i think japparts in lambton had a couple of fwd 4age corollas there. mine ended up costing me about $3000-4000 to convert. would love to turbo mine but funds aren't there at the moment. if ya need any help just send send me a message,am in newy too. this is my engine.
  6. mrduke replied to B.L.Z.BUB's topic in KE70 Projects
    I'd say double check for vac leaks,spray some aerostart around manifold and see if it's sucking air anywhere. If it's a cut and shut like mine it could be cracked around the welds. I also had to take the breather between rocker cover and manifold off cause when they modded the fwd manifold it is open and is a massive air leak,caused mine to idle really high. Luckily apart from the first motor i put in havin dodgy rings mines been ok. just had oil leaks. dizzy still leakin,can't get a seal locally. I've got a spare computer,map sensor and coil/ignitor if ya get really stuck. Shame i'm too far away to help.
  7. mrduke replied to B.L.Z.BUB's topic in KE70 Projects
    i'll have a look in my box of bits in the shed,i know there is a computer and may have a map sensor as well. i'm in the wrong state but if ya get really stuck could maybe post em up for test purposes(would need em back though). i'll let ya know what i have tomorrow. water level ok? my gti used to hunt when level was low causing coolant temp to have dramas.
  8. mrduke replied to B.L.Z.BUB's topic in KE70 Projects
    just one muffler after diff,no cat. might get a hotdog put in under car where front muffler usually goes and see how that goes. :hmm:
  9. mrduke replied to B.L.Z.BUB's topic in KE70 Projects
    what size exhaust and what mufflers has it got. not 100% happy with the sound of mine. mine sounds a bit tinny,not as throaty as i'd like. could be the standard exhaust manifold,have 2.5 inch primaries and 2.25 inch exhaust from there. maybe another small muffler or thermowrapping primaries might help. what ya reckon?
  10. mrduke replied to dougyboy's topic in Rollaclub Rides
    got a tvis plate between manifold and head? if it does,prob bigport. looks like a bit of work to do.have fun.
  11. pulled my spare dizzy apart today,got inner seal comin tomorrow for a coupla bucks, 6200 bearing for coupla bucks. hopefully back together tomorrow and back in car and oil might stay in the engine. :P
  12. hey there,the distributor on my 4age is leakin a fair bit of oil now so it's time for a rebuild. have seen a write up about it using a rebuild kit from a place in canada called kbox.com. does anyone know anywhere in australia that i can get a similar kit. the kits only about $30,just wondering if anyone has sourced anything locally. thanks guys.
  13. my ultimate dream car is one of these motors with itb's in a black '72 corona mkII. just gotta win lotto and it'll be a happenin...
  14. hook them up to cooling system.I think one of mine goes to pipe out of back of w/pump,the other to a tee piece i have in other heater hose. hope pics make some sense.
  15. yep,looks like the two water pipes on t/body not hooked up. didn't have mine hooked up originally and it idled really high. the two pipes sticking out the bottom of t/body that are blanked of need to be hooked up to cooling system or you can take the fast idle unit off the bottom of the t/body and blank that off. hook up the pipes,works relly good on mine now.have fun...
  16. yeah,go for a manual ae71.that way you will have g/box,x members,tailshaft,radiator etc. all you would really need to do is maybe get 4age front cut and start with that. you will need rwd inlet manifold or modify fwd one. get extractors and exhaust and mount up fuel pump. just did it all on my ke70 and it cost me about $4000 to do conversion.
  17. mrduke replied to mrduke's topic in Rollaclub Rides
    lookin forward to doin a bit of racin soon. gonna give her a run down the strip and up hills. fun fun fun.
  18. mrduke replied to mrduke's topic in Rollaclub Rides
    gettin an 8in cannon on the back,that'll be FULLY SIK!!!
  19. mrduke replied to mrduke's topic in Rollaclub Rides
    Woo hoo,car goes in tomorrow to be rid of the standard piss ant 1.5 inch exhaust. goin 2.25. hopefully sound better and go better. sounds like shit when ya get up it now.
  20. Just out of curiosity where abouts do you live? Maybe someone could help you out if they live nearby?
  21. Bit more info might help. 1. does it wind over but not start? 2. have you got spark when it won't start? 3. can you hear fuel pump working when it won't start? 4. do you have injector pulse when it's not starting? Basically speaking you need to see if it's a spark issue or fuel issue causing you the headaches. Sounds like it'll be a bad wiring connection causing intermittant problems. Double check powers and earths for computer and fuel pump. Good luck mate,hope ya sort it out.
  22. Have read that it's possible to run a 4age with standard computer and turbo it and all i have to change is injectors and map sensor. supposedly 4agze injectors and 4efte map sensor are used. does anyone know if this will work? Do 4agze's use afm or map sensors? any other map sensors work?
  23. map sensor and i think it's an intake air temp sensor on manifold have similar plugs. maybe they could be switched over? don't know if they can though
  24. Just done this on mine. 1. ae71 engine and g/box xmembers 2. ae71 hydraulic clutch setup 3. cut off water pipes just off w/pump as in guides on website somewhere. 4. mounted intank efi pump onto end of pickup in tank. 5. wiring up wasn't too bad. theres probably guides on web. think mine was from club4age. 6. t50 g/box with modded t/shaft,standard diff ok. 7. exhaust. extractors preferable. have fun,much better than 4k.
  25. mrduke replied to mrduke's topic in Rollaclub Rides
    Thanks Rian,it's really grown on me now. originally didn't like the plastic bumpers,always said real cars had steel bumpers but i think the slant front suits it so it'll stay. The bumpers aren't perfect so i'll get some new one's eventually. More power is always on the cards $$$ aren't. got the other motor at work. Will save up slowly,plan is rebore with forgies,t28 and microtech. Should be fun,just hope this motor holds together now.Lookin forward to toyotafest in sydney in a couple of months.
