Trev
Donor
    6398
    29
Everything posted by Trev
  1. Check to see if the thermo switch is still connected, Its the green plug on the thermostat housing.
  2. Is this an auto or manual? The automatic timing should be set to 0 BTDC and the manual 5 or 10 (can't remember) BTDC.
  3. They look a bit like ST185, I will look at our brake collection at work today and see if I can find them.
  4. My rent just keeps going up, I swear that they try to make it so you can't save anymore.
  5. Ha nah man there was no issue, I have always said to my mate to make his rx2 into a sleeper but its a bit hard with a 13bpp, I have always wanted to see someone do something as creative as what you have done with it, Have you got any running vids?
  6. Yes but with all the people convertion to big singles its sometimes more appropriate to do so.
  7. http://www.rollaclub.com/board/?showtopic=12429
  8. What Simon said.
  9. The reply to 13BT_KE20.
  10. Have you got the timing light direction going the right way, I have seen it reversed and believe me it puts you off.
  11. I have to think now as the engine layout is different, It is the rear most intercooler pipe connector, The car still made boost but it wasnt alot, It also had a rough run every now and then but before you do that check to see if your engine belts are tight.
  12. You can use castrol vmx80 in the charger, Make sure the inlet hoses arent split, The mr2 i drive had a bad power issue, Found a split hose.
  13. Where did my post go?
  14. Just thought I would add, I guy I know (met through a mate at work) has an MA70 with a 1JZGE in it but he bolted on a turbo and runs the standard ecu with 13psi, He managed a ET of 12.90 last week, Not phuckin shabby at all.
  15. Must of been the weekend for finding old twisted cars, I found an escourt out at kholo on the weekend that i have not seen in years, It had been washed downstream a bit more.
  16. Sleeper plates on a rotor, Nice. Did you get anymore pics of the noble? I didnt know any existed in Aus, Good line of cars there.
  17. Well i'd prefer to go to the gold coast so put me down.
  18. http://www.rollaclub.com/board/?showtopic=24476
  19. Where in Ipswich are you?
  20. I knew you were talking about the tags but i didnt realise that you seen everything that people added, I thought you just tagged your own stuff.
  21. What does that mean?
  22. I came across this article: http://news.ninemsn.com.au/article.aspx?id=648829 http://en.wikipedia.org/wiki/Spoof :) :P :D :jamie: :dance: Look girls, A new recepie.
  23. I don't mean to be rude but its people like you that f@$k up car values, Its the same way takumi tax was invented and why some wanker paid $600,000 for a fukin falcon (now everyone thinks that their GT is worth that much).
  24. The black wheels look tops on it.
