RO78IN
Regular Member-
69 -
Everything posted by RO78IN
Toyota 3K With New 5K Electronic Ignition - Vacuum Ports
RO78IN replied to RO78IN's topic in KExx Corolla Discussion
So using a 6AL-2 system would be the go then? http://www.msdperformance.com/Products/Ignitions/6530_-_MSD_Digital_Programmable_6AL-2.aspx Then remove the mechanical and vaccum advances? Then wire in the 6AL2 as per this manual: file:///C:/Users/RemoteService/Downloads/6530.pdf using wiring of page 6 figure 3 (at the top)? Does this make sense and is the right way to play? -
So the engine specs are: HEAD WORK: - changed combustion chamber profile to be even instead of that silly peanut shape - massively oversized valves - ported head - pretty big - Comp ratio is 12.5:1 static - around 8.7:1 dynamic Cam - Tighes 413 (259 @ 50" - massive) Motor - fully balanced bottom end GSXR1100 motor cycle pistons and H Beam aftermarket 4AGE rods Carbs - Twin webber 40mm (also have DHLA45's if needed) Still road registered (LOL) but more for hillclimbs and whatever -
Thanks Guys, I'll pull it down tonight to see what we can do about locking it up. What is your preference for Coil and mappable ignition controller? -
Ok, so searched for the last 30 minutes with little success. I'm building my 3k now, and the new 5k dizzy i just bought from Golbys has 2 vacuum ports. What the hell am I meant to do with these? Hook one up (and if so - which one) or both? I've heard that the curve on these is pretty shit > which is ok, its for a race motor, so hopefully it will be spending its life north of 4000rpm anyway, but is it worth locking it? Thanks in advance for your help matt
So that 3k I bought purely as a runner to get it regod? Turned out to be a fully balanced bottom end, polished rods and what looks to be lightened pistons. So I decided to put the head and cam on it as well as the flywheel, shit does this thing move... 10,000rpm and an absolute ball with the dcoe40 which we fitted just yesterday... I'll put up a video, 5000-8500 happens in a flash in first gear. Really needs a 4.5 or better diff with 5speed...
So I've been playing a little bit lately. It turns out that this little 3K i bought and stuck in the car for ReGO is the perfect bore size and Everything else. So the Flywheel is off getting lightened, Gearbox is getting resealed, and i will finish polishing the crank this weekend and get the whole assembly Balanced this weekend. I have the GSXR rings, wrist pins clips and what not on order currently, so hopefully that will only be a short amount of time before they are here, and we can slap this thing back together! In the meantime, we've started on the Chassis side of things... Building a race car - even on a tight budget - is not a 'cheap exercise. SO at the moment, we're trying to gain speed the slowest but cheapest way possible - remove weight. So the attachments are just a small idea of what we're up to. All the interior is gone, and the seam welding should start this weekend also as all the sound deadening is gone. Slowly but surely, we're getting there!
Short Answer; I want to track this thing. I am building a 3K engine with GSXR pistons, 4AGE forged rods, balanced Crank, and eventually, Turbo. game plan is to rev the thing to 10,000+ rpm. I currently have the engine out, and doing all the lightening to the chassis + seem welding, just wanted to know if i could get away with it, as i have a set here from my AW11 (that has 15x10s on it)... Now you can get Hosier 275/35/15 tyres, and in a little tiny chassis like that, i think with the little 3K, you'd never have to brake!!! Mid corner speed = fast lap times.
Best Place To Buy K Series Extractors?
RO78IN replied to megamannz123's topic in KExx Corolla Discussion
Theres a Dude at the end of my street that sells them on eBay (they are grey) and they are a total PIECE OF SHIT... I had to spend like 6 hours to make them actually seal down on the head. The flange is too far away from the bolts, he has welded the runners all the way to the edge of the flange so there is NO flat surface to use to clamp the ʞ©$ɟer to the head, Then, Ext from cylinder 3 comes out at a small angle that means getting a bolt in there is actually a physical impossibility... In the end, i had to heli-coil the head, fit undersized studs, Have 2.5mm thick washers made up to go under the 10mm flanged nuts (small stud size) then had to grind them away at certain points to clear the welds to it would actually touch the flat flange section. After all that, 3 still leaks a very minute amount... :down: So irritated (if you cannot tell!) -
Hi Guys, Done a bit of research and have seen that people have fitted 15X9 with zero offset and have gotten away with it, however i'm trying to get 10's on there... I've got flares to cover the width outside the guards, so I'm more concerned with what offset i'll need to clear the suspension. Can someone help me out? THanks matt
How! That thing looks decently fast! Obviously you've got that cam issue sorted out??
I'd love to have another crack. Great couple of mate bonding weeks sorting the car, then an unreal weekend racing with a bunch of like minded people. I googled obviously, but didn't see anything like it in aus, was just wondering if any of you knew of anything...
Hey guys, do any of you know if this has ever been attempted in australia? It looks like an awesome concept, be a great weekend with a bunch of friends. I've raced one in the states when I lived there, but that was a while ago... Anyway, any news would be great. Thanks Matt
HI Altezza; I never rebuilt these carbies, but did change a few of the upfront settings to new jets (what i could purchase anyway...) Now that i think about it, the mis-behaving carby did look to have a little water damage inside. I might take her apart and hopefully i'll find a little air channel or something blocked. If that don't work, i will do as you suggest, swap everything and work backwards. Thanks mate! :)
Hi guys, running a pretty hot 3k, with twin dhla45s on it. I know they are too big (plan is for 10,000+rpm) but these are the settings: 34mm chokes 135 mains 7772.7 emulsions 190 air correctors 55 idle set, 33 pump jet Theres a big flat spot on jet change over, but the main problem is that one carby is running MASSIVELY rich bottom end, so much so that within 10ks driving, the plugs are black. All the jets seem to be the same, emullsions clean, floats the same. Is there something that I'm missing? Thanks in advance. Matt
Let me be the first to say: HOLLY SHIT! This thing looks like it will be serious!
Haven't done this for a while That perfect condition 5K motor lasted about 150K's before a big end nearly sent the rod flying out the side of the block. Car has been off the road for nearly a Year now, but I managed to get a running 3K (that sounds good, but there's a noise my not so sure about) in it to get it going + Rego'd. The crank that we had polished and what not has been sitting, and needs another clean up and then final balancing. The GSXR1100 pistons and rods then need to be assembled and balanced. Then we need to lighten up that flywheel a Tonne! In the mean time, the head is practically good to go, as is the cam, so as soon as I get the car back from the Blue-slip, I'm going to sort out the carby jetting a lot better, put this 413 cam in it as well as the crazy head and see what we have. IT will be a bit of a waste on an un-balanced bottom end with a bullshit heavy flywheel, but it will tell me a little more about if the dynamic Compression Ratio is near it or not... Anyway, hopefully have some photos up tonight.
Scratch that :oops: I wont be able to drive that far to see it!!!
Updates, PLEASE... I love this thread.
Well I managed to get a drive in this afternoon, so much better, it's not even funny.
I need to rant a little bit. I bought an engine and carby set up off two different people, both stating how awesome and bolt on they should be. So far, - the engine was seized - head gasket was shagged - Timing was on 30+ degrees advance - Carby manifold needed around $150 spent in machinnig just to get it to bolt on - Fuel Pressure reg that came with it = totally Shagged - Tuning is no where near it... So i got most of this sorted out, but it was still running shit and wouldn't rev above 5000 rpm - for a 'worked 5k'... The guy had done the cam, so i feared the worst and bloke so far he surely hasn't dissappointed- cam was a tooth out. So for the last 2.5 hours if been fixing that, and now hopefully it shouldn't be too bad. On the plus side, 10 degrees timing is perfectly in the middle of adjustment, so can't be too bad. Just want to get this thing running so i can start playing with the suspension... Anyway, everyone in NSW, we should arrange a cruise so can actually do something with this group. The NSW regional section is like a ghost town!
Matt from the Wollongong Area too. Hopefully the KE30 2 door will be on the roads in the next week or so... Should try to hook up a few and hit the pass or something...
We went with the Tighe 413 cam. Advertised duration is something like 310/315 and at lift 280ish. Power band is quoted as something like 3500 to 9500rpm. Ideally we'd actually go a little larger, but at this stage, it will do for reliability testing and what not. my plan is to build the engine over christmas, get it the car, FLOG IT for a few months - around 2500 K's and then tear her down and see what we have. We have the head built, intake and exhaust. So its really only going to be getting the block together and in the engine. Crank should be done by Sunday night, and I'm dropping the block off to be line-bored. Bores were in surprisingly good nick. Quick clean out and all good. I'm going to run with the Clearance specs from the motorbike engine i stole the pistions, rings and gudgeons from. Other than that, the 4age rods and the pistons should drop straight in. Compression ration may be a litte high, so I'm planning to dry run the block and see the deck heights between the tops of the piston and the top of the block.
I also pick up another 3k block this weekend, and will get about stripping it on Sunday hopefull and start mocking things up. Ordered a billet CAM from Tighe today also. At this stage, I'm running as hard as i can with a Standard-ish engine. Everything will be balanced, dynamically and statically, but not the funky roller lifters or rockers just yet. I really want to prove that they can rev first off, so i will put a the massive cam in it, with the rods, pistons and what not, slap it together and see where it stops... Hopefully i plan to get that happening, built and in the engine in the chrissy - new years break, once the marrage / honeymoon and all that stuff is finished.
Well i've been having an awesome time trying to get this thing running. I think i spent around 10 hours just trying to get manifolds to line up correctly and what not, restudding the head, then undersize studing it, working out the inlet manifold was the wrong thickness, spent 2 hours trying to mill that.... Anyway, finally got it sorted and got an exhaust made up for it, and it sounded AWESOME. Anyway, for the last two nights been trying to sort out a phantom fueling issue. I'd get no more than a 1k from home and she'd stall out. Try and crank it a little while / sit and i could drive another k... At first i just thought it was empty, fail Then i spent an hour last night converting to a electric fuel pump, removing and Wiring, no resolution. Then went back to it this morning to ensure it was a supply issue, and sure enough, hardly any fuel ran out, turns out it was the FPR allowing pretty much NO fuel out. So the 1k must have been all that was left in the carby bowl... Went for a drive just now and she is great. Sounds awesome. I'm taking a vid tonight and loading it i like it so much...
THIS LOOKS AWESOME. Loving the wheel colour and car colour combo, looks neat as. Do you have a proposed finished time?
