thanks mate!
wasn't easy! had problem with residual crap bein in all the corner and the paint didn't want to stick!
hard to get em perfectly clean!
from left to right!
water temp
aftermarket electric speedo
and tacho
in the console the final arrangement will be volts fuel and oil pressure!
that way i won't need to retain any old guages!
they will all fit snugly behind the original holes! that way they look stock!
Tonights update!
did this this arvo!
installed my guages into my console!
gonna sand smooth and then paint the same as the steering shroud!
all glossy and silky smooth!
yeah only thing is i'm trying to get rid of the last of the colour?
what makes it come off?
heat? + water = humidity?
anyways did more to the gf's car!
retrimmed plus amp!
freakin pumps!
$150 plus postage!
you have to have the right rubbers though!
also 16v?
for you guys i'll be sending them without the hole for the rubbermount drilled!
that way you can position them wherever you need!
Funny that though!
i had em the whole time my rolla was on the road!
they flashed quicker but.....
you can get resistors that fix the problem!
i also have these as well!
so they do work!
Ok recently purchased these ke30 lights.
the lens colouring has come off for the most part!
now i have LED lights that are coloured!
so i wanna make em clear!
anyone know a good way to remove lens dye without destroying the plastic?
ok
power in- straight from battery. keeps the computer memory alive.
acc in- i get from ignition barrel. but to what ecu pin?
fuel relay i get now thanks medicine man.
i have an auto ecu.
so the nuetral start switch i earth to the starter relay.
ok wats next?
had a look and i don't get the CAS bit?
oh man i am over my head! lol.
the alt is totally diff from 4k one?
i though just to wire it straight to the batt?
and the thermo i can wire to the ecu as well? i got a davies craig setup for that anyways.
thanks for your help!
i have been reading but i'm having some trouble with it.
those open circuit relays, can get from wreckers? or good idea to get new from toyota?
when you turn say headlights and demister and heater on all together the revs of your car changes does it not?
get slower or faster?
the 4age ecus have a control in them to compensate for the sudden power drain?
i could be wrong!
ok the fuel pumps ground to the ecu but where do they get the pwer from? any acc.? or straight from battery?
so if the body loom is left alone then there is only about 2-3 wires to worry about?
signal, grounding and constant power?
