Everything posted by SLO-030
Birthday Cruise Info :) Please Confirm!
sunday cruise sounds good. My birthday is the closest (next day) I WIN ;) Thinkin of takin a few days off :yes:
Spotted
Saw it coming out of Collonades this arvo on the way to help sus out Lucs Gf's not running MX5. just a EFI fuse :yes:
Cruise This Sunday 8th Feb
ke70kid: if you wanna cruise i can send ya a heads up message when we get close to Shepards Hill Road (heading north via South road)
Starting A Wet Engine?
yea, try blowing the distributor internals dry with compressed air.
Slo-030. Healthy Dose Of Aussie Muscle Ahoy
You know all about that, don't you Jason :yes: Spare seat usage has now been revoked.... ..now un-revoked (voked?) hahaha, NO
Hmmmmmmmmm, interesting. I don't think i'll be needing stainless, just gonna get painted black anyway. If i can supply some steel plate 8mm maybe, we could possibly sit down and make some CAD drawrings. least they'd all be spot on specs :yes:
you wont be seeing it mate :yes: Shall be so quick all you will see is a yellow flash *cough cough*
well imagine that, with a enlarged hole for the 30/55 shifter position, then more enlargement for the 70 position
just have to widen the rear of hole in the floor. was an auto so it has an elongated hole in the floor. doing the same as when the previous owner did when he put the 4spd in.
Rollaclub Birthday Cruise :)
i will prolly have an esky in the car too. Gonna dump the all the tyres and tools and spare parts out of the boot and with the full esky the car should weigh the same :yes:
Building A Ke70 2 Door
IMPORT :yes: i think they have T series engines from stock too.
Changing Headgasket
the C on the end of 4K-C just means its running/built to Californian emmision standards
4k Firering Order
1342 :yes:
The "omg Guess What Happened Today" Thread
Fast and the Furious Coffs Habour Drift
26th is a thursday. Id say 28th would be a better date for it :yes:
Thoughts On Sa Corolla Scene
yep, thats it. I'd try and make it to as many as i can anyway.
Always blaming it on the net connection :P
just import a TE70 (i think that what they're called). that way everythings in proportion :P
Fortnightly would be good for me. Even if you do it weekly but alternate between wednesday and thursday, some people like me may have early starts and i can imagine these nights ending close to (quote doug, "pumpkin hour").
Changing Headgasket
10 bolts :P if its warped, ive been told to torque it down as per usual, heat it up by running the car (idle) then torque it down again,
Changing Headgasket
No worries mate. Just a tip, run the head bolt down into the threads into the block to make sure its not stiff, it could cause inaccurate torquing. also a drop of oil on the threads and under the head of the bolt will give you more accurate torquing :P
Ella's 83 Ke70 (molly) Flat Front Custom Paint
bahaha, nice work. I too have friends like that. Just that if i over use one of them, not much gets done :P
Changing Headgasket
I just did my new head gasket for the first time on the new 4k. nothing much to look out for. just make sure you clean the head up (if any of the old gasket sticks to the head or the block) and don't rest the head on its mating surface :P . what brand head gasket are ya using? and yes, it does run pushrods.
Heatwave
your tellin me :P Probably mean weather all over the country will get worse. cyclones,heat waves, floods etc.
