Evan G
    3817
    23
Everything posted by Evan G
  1. +1 for rotor button!
  2. wheres mr alltezzaclub when you need him :P
  3. whos 30/55? did you try your keys in the one at the mall? :blinks:
  4. ill leave the old date 10/10/10!
  5. my mushroom filter sounds better :blinks:
  6. i borrowed it from work. i think its a lamba meter not a o2 sensor? went for a drive showing 10.5 and not moving i reckon it might be the sensor
  7. yep when hot. ill install the o2 sensor and go for a drive
  8. i havent put it in the car yet.. just want to test it but even with a good does of brake cleaner it should change?
  9. ok my jay car kit is assembled but problems with the wiring! I'm using a 4 pin o2 sensor white - (continuity between both white wires = heating element) white - ^^ grey - earth (continuity between grey and o2 housing) black - signal for the jay car gauge theres 12v, IN (signal) and earth if i earth out the signal for the gauge, gauge shows 7. if connected to the o2 sensor. it shows 22 um help please? edit - i connect the signal wire to the gauge and sprayed the o2 sensor with brake cleaner, value didnt change ------------------------- orite Ive got 4 o2 sensors (3 wide band and a narrow) threw the narrow in, went for a drive. showes... 10:1 under full load drops down to 9.1 when the gas pushed to the floor (accelerator pump) released the gas at 100kph, dropped down to 8.5 then crept up to 9.5 * i have a miss at idle when i push the brake pedal, so pumping the pedal at idle = 8.1:1 * with the choke on at idle 10? i tried another sensor and got the same results NO wonder i chew through fuel!
  10. ke - 1970 infront of thomastown supercheap! i didnt see a blue van there or i would of poped in and said hello
  11. :blinks: coming on the cruise to king lake? would love to see this in action
  12. don't forget the r31's got banned :blinks: i hate it when people say yea fords shit go holden? ummm it all depends moslty on the driver. don't they use the same engines? (ive heard?)
  13. how many members wont be attending due to bathurst? if its only like one or two ill leave the date of 10/10/10 but if its like 7 ill change it
  14. might move the date to the 3rd/10/10 if alot member can't make it due to the Bathurst weekend? VOTE ON 1st PAGE!
  15. sticker i want made
  16. when i was changing my leafs i decided to jack the diff up until it hit the bump stops ^^^ thats on 13's
  17. with a wagon that low its gonna handle like a absolute pig!, yea sure it would look "hetick ulay" but i feel sorry for the passangers/driver (unless they have big boobs :blinks:)
  18. 5ks use 4k cranks anywitch way (I'm pretty sure) so aslong your using 5k rods/pistons, it wont mess with the stroke.
  19. i didnt use flour, i used a banana peel :blinks:
  20. make sure you balance everything on the bottom end for a smooth engine all the way to redline
  21. nah mate all good, so i wasn't loosing my mind when i saw tention monograde DD thicker than ep80w? i better cancel that appointment with the shrink
  22. red oil is the engine oil? who the heck makes red engine oil? so the gearbox oil was thicker than the engine oil cause it was the slower one to run down?
  23. :blinks: wow!
  24. ufc f@$king rocks! GSP, brock lesner, rampage jackson my top 3
