Raven Posted June 2, 2007 Report Share Posted June 2, 2007 Or if you don't wanna be an amateur wanker with a welded diff, invest in a T-series 1.5 or 2-Way LSD. Quote Link to comment Share on other sites More sharing options...
anastasios Posted June 2, 2007 Report Share Posted June 2, 2007 also welding a borgy is a pain in the ass and will break shit, if you do random burnouts all over the place Quote Link to comment Share on other sites More sharing options...
Lukey Posted June 2, 2007 Report Share Posted June 2, 2007 Hey hey i was talking to my dad about weilding my diff and he says no way because welds can snap. So he told me that its better to get led (like from fishing sinkers) and melt it all up and poor it into the diff housing. It wont snap and if u want your old diff back all you have to do is heat the led up again and poor it back out. :bash: Quote Link to comment Share on other sites More sharing options...
Redwarf Posted June 2, 2007 Report Share Posted June 2, 2007 (edited) Hey hey i was talking to my dad about weilding my diff and he says no way because welds can snap. Not if it's done properly. A good plated and welded diff will never break the welds. Everything else tends to let go after a while though. I've never had a weld let go, mine usually did the pinion gears. So he told me that its better to get led (like from fishing sinkers) and melt it all up and poor it into the diff housing. It wont snap and if u want your old diff back all you have to do is heat the led up again and poor it back out. :bash: Lead is too soft. I know someone who did an aluminium pour into one, and that was effective for a while. The best way is still to weld them and plate them. Edited June 3, 2007 by Redwarf Quote Link to comment Share on other sites More sharing options...
Nat-ae71 Posted June 2, 2007 Report Share Posted June 2, 2007 Hi, I own an ae71 with a locker. It's mainly used for track/drift/spirited driving, so I find the locker to be a good idea, at least untill I save enough to get a decent lsd/lower diff ratio for my t series I have. If your driving your car everyday it will piss you off very very quickly - 3 point turns suck hard in a locked diff vehicle. That said if you are going to compete in any sort of motorsport lock it up, if you're pushing hard on the track I feel an open diff is going to bite you - it is unpredictable and doesn't allow you to properly control a slide. Also after doing a hill climb with an open diff I would never do it again, if your looking to runa decent time you won't do it with an open diff. NOTE: this is what I have found in my travels, I am no expert, but this is what I have foudn works for me. I say weld it up, rolla diffs are cheap and there is nothign stoppping you from putting an open diff back in there Quote Link to comment Share on other sites More sharing options...
Sheqel Posted June 2, 2007 Report Share Posted June 2, 2007 They force the car to understeer on entry into the corner, but fun oversteer prevails on exit. Compression lock drifting is excellent with them. Parking is shit. To sum up, great for a weekend rally car/paddy basher with small power, shit for anything else. Quote Link to comment Share on other sites More sharing options...
coln72 Posted June 2, 2007 Report Share Posted June 2, 2007 Not if it's done properly. I good plated and welded diff will never break the welds. Everything else tends to let go after a while though. I've never had a weld let go, mine usually did the pinion gears. Ditto - usually end up as metal shavings in the bottom of the housing. Last one the biggest piece i found was less than a third of a gear. We have never plated ours, but we weld the pinion gears to each other and the diff carrier as well. This gives more weld area. We also use stainless rods to do the welds. Quote Link to comment Share on other sites More sharing options...
anastasios Posted June 3, 2007 Report Share Posted June 3, 2007 yea you are goin to snap other things before a weld goes, just weld it and get it out of your system Quote Link to comment Share on other sites More sharing options...
kangaroosa Posted June 3, 2007 Report Share Posted June 3, 2007 Whether you should lock the diff or not, can all be decided upon by one question. Do you have Insurance? If yes, then don't lock it. If you decide to lock it, then you may as well cancel your insurance and spend your refund on getting the diff locked. Quote Link to comment Share on other sites More sharing options...
matta Posted June 4, 2007 Report Share Posted June 4, 2007 in my personal opinion i reckon its so dodgy, for daily driving id leave it open and if ya going to drift it buy a proper LSD i wouldnt muck with it. Quote Link to comment Share on other sites More sharing options...
