Either does mine... On the fire wall!!
It does on the build plate... If you can make it out.
ARE YOU TRYING TO OUTSMART GOD!!!!!
Have a better look
And the build plates not the normal one either. Apart from the toyota emblem on the plate there's no jap writting and it says its "Manufactured by Australian Motor Industries LTD" and not the normal "Toyota Motor Co"
No, speedo cable is correct... sorta. Your looking in the wrong hole. KE55's never had hydrolic clutches, There is no clutch cable cause we are looking at an auto (Dip stick visible in pic) and as for the build plate they used both the Jap and the AU plates on the KE55's. Only diff is that the Jap plate will state that a Aussie Plant made the car.
Spotted this today. I've never seen a 120Y panelvan.
Toyota?? Shure!!
We were at dicks (Dick Smith) and I spotted more than one Bush!!
Both these bikes were rego'd together. 464 is on the left. 465 is on the right :P
