January 2, 200521 yr comment_26577 a surge tank i whould recomend or get your tank baffled and foam filled which will stop the surge to you get downto the last 10l is say but a surge tank gives ya a bit more protection and probly cheaper to. as for fuel line id run 7/16 or bigger cause then you'll have as much fuel as you'll want and if you go power hungry later on you wont have to upgrade it again mark Report
January 3, 200521 yr Author comment_26631 Well after geting the motor out by hand.... The car is almost it its worst stage. Only thin we could doo is remove the doors and brakes :lol: Dam you teddy, they though the motor was already out >_< its now one very sad corolla Edited January 3, 200521 yr by Jason Report
January 3, 200521 yr comment_26633 I think ive got a couple of rebuilt PBR slaves if you need them. Report
January 4, 200521 yr Author comment_26767 Ok ive been thinking about the fuel system, get a custom surge tank made to fit into the side bit go the boot (were all the tail light wires go) then use a VL pump as main feed and a 'pre pump' to feed the surge tank. But i don't know what ill will need for the pre pump, or is it over kill. Report
January 4, 200521 yr comment_26771 No, that's exactly what you'll need. For the prepump you'll need a low pressure high volumn pump, similar to what you'd use in a carby car, like a Facet style one. Would probably be cheaper than a high pressure one. For safety reasons I'd be inclined not to put the surge tank in the side of the car, put it closer to the center of the car else if you get a prang on the side you'll be in trouble. Report
January 4, 200521 yr comment_26772 are there any legal issues to surge tanks in the boot of the car? does it have to be ventilated? Report
January 4, 200521 yr Author comment_26773 I herd that it can't be inside the cabin? Or is the boot counted as the cabin? Other wise ill have to squeeze in the engine bay, or under neith :thumbsup: Report
January 4, 200521 yr comment_26785 It has to be in a separate "compartment" to the cabin. In the case of the KE70, you will need to seal off the boot from the cabin. I'm not familiar with KE70's so I'm guessing here. Can you fold the rear seats down in a KE70? Basically you'll have to get a piece of aluminium or steel sheet, and make a "firewall" between the cabin and boot. The boot is naturally already ventilated normally, through drainage holes in the floor. If you are going to get a surge tank custom made anyway, I'd suggest going one under the floor anyway, just to keep things neat, and so that you can actually use your boot space. In my car, I don't put anything in the boot because the thought of things flying around my boot and knocking my fuel pumps/surge tank over is no fun. And being a KE70, you can just get one specially made for an AE86 (Anthony Kellam sells these), AE86 ones go under the floor because the "boot" is the same compartment as the cabin. Report
January 4, 200521 yr Author comment_26792 I was always planning to make a cover for the battery and surger tank, so its sealed. What do you mean, under the floor of what? Report
January 4, 200521 yr comment_26795 Under the floor of the boot. So you were going to make a cover to seal off the battery and the surge tank together? Fuel and spark, all happy in one box? Report
January 5, 200521 yr Author comment_26802 hmmmm good point never though of that :thumbsup: woops but battery explode any way from there hydrogen build up? ill find a good place under the boot then Edited January 5, 200521 yr by Jason Report
January 5, 200521 yr comment_26804 I think the one for the AE86 usually goes sort of behind the diff? In that space in front of the spare wheel, something like that. Report
January 5, 200521 yr Author comment_26805 Ok just had a quick look, theres not much room? How bigs your surge tank? Also do fuel lines have to be a special type of metal or can u just go down to any pluming shop and buy 10m of it? (metal) and what about the rubber? is there any place were i can get a few meters of that for connections? Edited January 5, 200521 yr by Jason Report
January 5, 200521 yr comment_26814 You'll have to speak to Kellam for that, or someone else who has one of those surge tanks. From memory I think they were 1L. Mine is 1L, but mine is in my boot, and mine is a KE35. Metal lines are just standard bundy line. I got mine from my engineer, I would assume any other plumbing shop would have it too. Rubber lines make sure you get EFI fuel hose. I got mine from... umm. Hmm, can't remember. Supercheap sell it, but only in small quantity. I got most of mine from one of the hose suppliers (look up yellowpages) Report
