4agze In Ae71
so has it been rego'd yet mate?
  • Replies 557
  • Views 293k
No and I'm freaking out at the moment. Cylinder one isnt firing well. Reason being, spark plug being hit by piston. After tearing my hair out and though I had put wrong plugs in I found a disturbing discovery that the head has been milled a significant amount. Being the noob I was when i put the motor together I didn't take notice of the massive shave that looks to have been done In its previous life.
It only smashed the plug once the motor has fired up, it dosnt change when its just reved by the starter. It goes from perfect gap to 1/2 gap in about 1min of running. I'm going to pull the head off and have a closer look, if any one could shead some light on this before I do so though would be grea
another little less time consuming way is to get another plug the same thread but shorter distance into the combustion chamber or maybe throw a washer or something underneith the plug
  • 4 weeks later...
just read thread.
great build, good luck with it
chuck a washer under the plug
Whats happening with all the other plugs? Bit weird that its only hitting on the front plug. What about a thicker head gasket? Or would that do little?
it ended up one of the metal washer/seals that hold the cam covers on dropped in the cylinder that what was hitting the plug
so time for another rebuild
luckly i only need a new head gasket. I cleaned all the crap and the seats and valves are fine.
Not at home (where the car is) so no progress.
Hey Jason hows it going?
Gotten around to getting it running again?
Travis.
Nope the sight in my garage is a horror story, had a lot going on in life but I'm on hoildays soon so maybe i can get back into the swing of things.
  • 4 weeks later...
i just went for ke70. yeh so what you need a new xmember, gearbox xmember and couple other things! if people want the flat front but want ae71, it's just better to get the flat front and hunt for the xmembers and everything else to bolt in
awesome build, I'm doing same build in my ke70.
this makes it look as hard as it really is, not like mumblezz conversion that was done in one post :)
I'm jealous coz mines still just an engine in a ke70 no wiring yet or anything
