Drown it in CRC for a day or so, then try taking it off again..
nuh i carnt figure out how the plastic lugs work, i don't want to break them.
Car looks pretty clean, rust doesn't look too bad. If you're lucky you might even be able to get "repair panels" to fix that up.
cool, i thought that was a lot of rust for a 'good' car :insane:
  • Replies 557
Hopefully by tomorrow we will have the bumpers off, the tow-bar off, degrease down some of the motor (rock cover & surrounding is a dirty female dog) , clean out the interior, do something with the radio & maybe work out a plan with this rust.
Just on another note
Did you know:
The Ae71 Spirit came only as the Spirit - not an SE, CS or CSX Spirit, but just "Spirit". Found out today, that along with its Tacho, Spoiler and colour coded insides / outsides, that it actually doesn't have an inside boot and fuel cap release (The CSX on the non-spirit and Ke70 does have one tho) AND the back air vents behind the doors are different on the Ae71's compared to the Ke70's :insane: !
Also, The Ae71's have an auto choke, and the Ke70s have a manual one. When looking at the choke position in the Ae71 - normally there is a hole - well, thats what i thought anyway- theres actually a plug from stock they put in there, which i have never seen before. !!!
hehehe
hmmm.. one more thing- All the Ae71's appear to have a much clearer Speedo console thing - where as all the ke70's are slight tinged yellow... ehh could never figure that out.
Part 1 - Body Work
It was a productive day, Teddy came over, and we pulled the back bumper.
Its a aftermarket which struck us both odd, had to get under and unbolt it... not a easy talk, considering the bolts were seized :insane:
Teddy showed my how to fix up the surface rust, got 1 area done. A lot to do tomorrow. We got impatient so will pulled the tape and the paint started to peel off... I hope I don't have to redo that part it's real nice.
I started on the spoiler, it was heavy cracking, its was through the paint even in some parts of the plastic, so the top was completely sanded down and tomorrow I will do the sides
Pics
PS now my fingers feel all smooth and weird
Edited by Jason
I think it was 2 years? It was somewhere on this thread.
Looking good guys.
Teddy: at the rate you're learning you're gonna be an AWESOME mechanic by the time you're my age (ie old)!
Yere about 2 years (a little under now), I want it fully up and running by the time I can drive.
Yere I don't know were I would be with out teddy :insane:
Paint over lap problems...
I have finished another area, but there is a major differences between the spray area and the normal paint, the re-sprayed part it much better.... how do I blend the different shades together?
Oooh that's always fun. You more or less have to "feather" the paint out, either by using a lighter coat on the edges when you spray, and/or sanding the edges out.
If you find a better way to do it, I'd be interested!
