OK, there seems to be a growing problem with the size of some peoples signatures so I need to remind everybody of the 150 pixel limit. Mainly this has become apparent to me because of my eee pcs small screen with some peoples signatures wrapping and taking up more than an entire screen. I will give people a leway out to 200 pixels before I'll remove your signature and PM you the original contents so you can correct it.
Examples of correctly sized signatures:
http://www.rollaclub.com/board/?showuser=103
http://www.rollaclub.com/board/?showuser=6
http://www.rollaclub.com/board/?showuser=885
http://www.rollaclub.com/board/?showuser=87
and so on...
Example of incorrectly sized signature:
http://www.rollaclub.com/board/?showuser=82 :dance: I'm dobbing!
This image is 200 pixels high. As long as your signature is under this size you'll be fine.
Alternatively post here and I'll tell you if your signature is too large.
  • Replies 35
Its OK for me but the 56k users might say otherwise (and there seems to still be quite a few of them around). 70kb @ 6kb/sec is gonna be about 12 seconds on top of a normal page load. Your call.
Eeek. Didn't realise it would take that long. If it means loading the rest of the page will take longer then I guess I should take it down, but if everything else loads fine and my sig just finishes loading later on, I'm find with that.
How's the page loading work? Would it load everything top to bottom or load the smallest files first? I can't seem to remember now that I think about it. :dance:
