November 10, 200817 yr comment_288792 Can somebody please explain the differance between a Silver and a Black top. I'm not up with new stuff, more into old, as in 2tg etc. But maybe its time to get into the now because i race against late model Honda's and Nissan's and quite frankly they are kicken my ass. Report
November 10, 200817 yr comment_288812 there is not to much different in the two, but mainly it is a tuning difference with the black top coming out in front with more power Report
November 10, 200817 yr comment_288842 not 100 percent but i think the black top just has higher compression theres probs more than just that tho Report
November 10, 200817 yr comment_288851 there is not to much different in the two, but mainly it is a tuning difference with the black top coming out in front with more power Thats crap, you got proof? *Goes hunting for the facts* Report
November 10, 200817 yr comment_288858 http://en.wikipedia.org/wiki/4AGE#4A-GE_.2820-valve.29 that give you a quick rundown Report
November 10, 200817 yr comment_288864 Also helpful http://forums.toyspeed.org.nz/viewtopic.ph...asc&start=0 Report
November 10, 200817 yr comment_288871 map sensor instead of air flow sensor, larger throttle bodies, higher compression, more inlet cam lift larger exhuast ports Report
November 10, 200817 yr comment_288900 Different cans of paint. is that like same shit, different bucket trev!? :bash: Report
November 10, 200817 yr comment_288903 is that like same shit, different bucket trev!? :bash: Yeah basically. Nah seriously the guy to speak to about the differences that i know of is Matt (littleredspirit), He has had both engines in the same car. Report
November 11, 200817 yr comment_289107 as said above. also the rods and crank are lighter flywheel is also lighter. thats really about it. Report
November 11, 200817 yr comment_289118 Different cans of paint. The design of the cam cover is slightly different too, but from what I gather they are interchangeable (like bigport and smallport) Report
November 11, 200817 yr comment_289126 I have done my best to write a large part of the wikipedia entree on 4a engines so if anyone finds anything wrong please let me know. here is an article I wrote, i need to add some more of the minor things I have found since then: http://www.ae86drivingclub.com.au/faq/inde...4age/20vengines Report
November 11, 200817 yr comment_289132 oh and by the way if I am not mistaken the metalic grey "silvertop" is painted while the blacktop colour is a plastic pigment instead of paint. :bash: Edited November 11, 200817 yr by Sam_Q Report
November 11, 200817 yr comment_289136 They're very comparable in terms of power and specs on paper. But the blacktop and the gen II silvertop make thier power much smoother up top. You can tell the Gen1 and 2 motors apart from the linkage system that actuates the throttle bodies. Gen 1 has an extra lever in the system, whereas the later one is a single piece to link the throttle cable to the actuator. Cam timing is advanced slighly on the blacktop, but the best part about them is the light weight flywheel. Both motors don't run as well on our fuel without the use of an aftermarket ecu. Report
