April 22, 200917 yr comment_338822 hey all I will try update this thread as I build my ke70, it's a racecar I intend to use in a class called special saloon and the rules is somewhat similar as the old gr.5 I once had an old thread but I want a fresh start as this no longer is a "track car" I will use the 4A-GE blacktop, and for chassis I aim for lowest possible weight, I will try my best to be around 700kg included driver + fuel engine is moved approx 20cm further to the rear, pedalbox and driver seat is also moved approx 20cm and the car is lowered approx 20cm, roof height is 120cm ( stock 140cm ) right now the rolling chassis weight 386kg which I think is a bit to heavy so I'm currently drilling alot of holes to save some weight.. not much but everything helps please note the bathroom weights for corner weighting the car.. Edited September 11, 201214 yr by David Report
April 22, 200917 yr comment_338824 lol that awesome weighting it with bathroom scales looks sweet as Report
April 23, 200917 yr comment_338935 I want your workshop! Looks good so far. I can remember reading your old thread but that was a long time ago. Will be looking forward to updates :hmm: Report
April 23, 200917 yr comment_339037 Sweet looking ride, will be good to follow & see how it goes. Report
April 24, 200917 yr comment_339148 I'm going to be keeping a close eye on this, what a wicked base to start with in a 2 door 70. Keep up the good work and look forward to seeing your progress :hmm: Report
April 26, 200917 yr Author comment_340021 I bought some aluminium sheets this week ( 0.75mm ) so I made some templates I also mounted the steering column ( the tape construction is only temporary :P ) Report
April 27, 200917 yr comment_340269 looks good, you must of saved heaps of weight there are so many holes in it Report
April 28, 200917 yr Author comment_340612 waiting for more pic ,bump . LOL? this is not a salesthread or something you can bump like that, I don't build this car to entertain you if you don't have something useful to say, don't say it more pictures won't come before I've taken them, and that won't happen before I've done progress Report
May 1, 200917 yr comment_341361 Mate i just came a little it in my pants when i first saw the photos of you 2DR *E7*........................................................ Report
May 5, 200917 yr comment_342305 quick question are you bracing ne of the front quater area and pillars as such, or are you just hopeing that your roll cage will add stiffness as wont having all those holes make the car more likely to flex Report
May 14, 200917 yr Author comment_344819 quick question are you bracing ne of the front quater area and pillars as such, or are you just hopeing that your roll cage will add stiffness as wont having all those holes make the car more likely to flex the rollcage is stiff enough to carry all the suspension pickups etc drilling holes won't make the chassis very much weaker if you leave enough metal around the holes I will make some more bracing around the front strut tops, probably a triangle out of 25x2mm piping or so Report
May 17, 200917 yr comment_345311 do you have a rough budget worked out for this car??? or a cost calcualtion so far? or is it build and buy as you go? just interested... chaars Report
May 17, 200917 yr Author comment_345453 do you have a rough budget worked out for this car??? or a cost calcualtion so far? or is it build and buy as you go?just interested... chaars I don't have a budget for this car, I simply use all I can afford if I knew how much I've used ( or if someone else know) I might been put in a psychiatric hospital hehe I've used well over a year so far and it won't be finished before April 2010 Edited May 17, 200917 yr by David Report
June 13, 200917 yr Author comment_351811 fibreglass parts is being made.. hood weight 4kg ( stock 14kg ) trunk weight 2kg ( stock 9kg ) that's 17kg weight reduction an old picture and with the engine in Report
