Car Security For Ke70
  • Replies 51
  • Views 32.5k
  • I once left my dog in the car while I ran into the shop (I was gone less than 10 minutes). I left the two front windows about half down. My dog (a Beagle cross Blue Heeler) used to sit on the floor of
  • if you have shit rims just remove all wheel nuts,..........................................they wont be going that far.
Doesn't that only cut off the idle circuit Evan??
So you can unplug that cutoff but drive the car if you don't let it idle...
really? ill try it going to work 2moro :P
That's the first thing to look at if a corolla drives fine but doesn't idle...learnt that the well not hard way but the long way.
I'm thinking of getting one of these, putting the leads on, turning it upside down, fitting a cardboard 'dam' around the outside edge and pouring it full of epoxy!
That makes it difficult to undo the leads...
Another option is a magnetic reed switch behind the dash that opens a circuit to a relay. You put a magnet on the dash (or where-ever) to make the car live. They have some potent little magnets these days, but the trouble is that you really need to easily kill the battery power, so it needs to be a fat relay taking starting current every day.
Everyone's thought it but I thought I should post
anyway.
Love it!!
He's up with the really classic Brit TV comics. The Two Ronnies, Steptoe & Son, Allo Allo, Fawlty Towers.. some great stuff!
i normally leave thumb pins covered in aids on my drivers seat :P
Blzbub always the master of horrendous MS paint photoshop :P
Food for thought.
To protect your car get the anz falcon (the bird, not the car) to watch over your car, like it's watches over your money hahahaha :P
if someone really wants to steal your car, they will steal your car. they will bring a flat bed truck and just drag it up by the front bumper if they have to. and if i was going to steal a car i woudl bring a flat bed with a Faraday Cage around it, so the little GPS locater things didnt work!:P
you just need to deter the joy riders. steering lock, an alarm, a kill switch maybe.
but on a K motor if you can unlock the steering, just need a new wire between the battery and your coil, the same thing for the fuel solenoid, push start it down the road, and off you go...
i think that the dinosaur on the roof is a far more effective solution.
I like the high tensile steel rod to gear shift idea. Simple, old school but seemingly effective!
Don't know if you're into Over Haulin' very much but that's how Chip Foose steals someone's car one time, worked a treat! Minus the Faraday Cage that is :P
