Ke30....... Will A 5l Fit?
Het guys just wondering if anyone knows if a 5L will fit in a ke30 and if so how much work is needed?
do you know how to use a grinder? any experance in butchery
its done plently of times check out the ke30 on youtube with a 253
Yeah i know how to use a grinder but no experance in butchery................. do you know how much work is needed? I was told it should fit in easly but don't really know much about the mechanics
Rather pointless question (not having a go at you just trying to help :yes: ), we have a KE10 on here with a big block V8 in it...
If you're happy to cut the car to bits, anything can fit. If not, no it wont fit.
The car will never be roadworthy and, unless you spend big dollars will be a pig to drive.
Thats good to hear as i really don't know much about mechanics........ why wouldn't it never be able to get roadworty if i got it enginerred and what do you mean by drive like a pig? Well what would you do if you had a 5l out of an ss and a ke30?
Actually i know why it wouldn't be roadworthy
it would handle like crap. It'd be extremely front heavy so you'd have to spend alot on suspension work to even things out. This would also make steering really heavy. And given the width of an 8 it would probably limit the steering lock.
And what ive picked up as a rule with engine conversions is anything will fit in anything. Just depends how much time and money you've got as to how insane you can go.
Also, you should never put an engine in a car just because you have a spare whatever in your backyard.
Edited by h1_roll4
Sell the 5L or paint it blue and send it to the bottom of the deep blue where it belongs. With the money you get from selling the 5L....you may be able to put a decent engine in the corolla without actually butchering it.
the easiest way would be to make a frame and mid mount it, use a G50 porsche 5 speed flipped then flipped, independant rear suspension, then figure out the 5L doesnt make any power so change that to a gen 4 motor, fully cage it and race it as a sport sedan cos they sure as hell wont let you drive it on the road, sounds all to easy with limited mechanical knowledge, talk to an engineer first
I came into this thread intending to ask why you would want to put a 3 litre diesel hilux motor in your corolla (5L)...
...then was shocked to find you'd had an even worse idea.
lol!!! I did have that thought I must admit...
put a 2gr-fe, or a 2zz-ge, or something of a similar nature into it, you'd scare the pants off everyone.
The last 5 litre holden v8 I drove was abysmal to say the least... and I've driven a LOT of fast cars now.
Robert.
