4age Pistons In 5k
hello! i want to ask you if the 4age pistons fit straight in to the 5k engine they need any modifications? thanks!!!
  • Replies 33
  • Views 42.4k
Pretty sure you have to bore the engine out a bit. But once bored out you can use the entire piston and rod combo.
you also need to machine the block down to get the compression up!
we machined ours down 1-2mm i think, could be more, depends on the compression ratio you want.
we thought it was well worth the effort, had a better range of pistons.
the Big End is smaller in size but this hasn't caused any problems, we have had the engine apart a couple of times and it was the first thing we checked.
It was/is all good, checked with a micrometer too.
Edited by TRD ke70
Some Apexi Seals will be needed too :jamie:
But as the others said, they can fit, but why not go a 4age anyway?
haha sounds like a perfect opportunity to put a turbo on the motor with the lowered compression :jamie:
yeah, but its a done and tried swap. cheap enough if you get parts at a good cost, and do work yaself
He lives in greece, I don't think there are many bogans wrecking corollas around there lmao
haha sounds like a perfect opportunity to put a turbo on the motor with the lowered compression :D
does any one know what the compression would be. would it be low enuff to run 16psi of boost ?
why do manuals engine combos have CR of 9:1 and autos 8.5:1??
