February 6, 201016 yr comment_411480 my 3K is ticking really bad but is full of oil, anybody have any ideas ?? Report
February 6, 201016 yr comment_411483 my 3K is ticking really bad but is full of oil, anybody have any ideas ?? Have you checked for explosives, timer ect. Report
February 6, 201016 yr Author comment_411485 Have you checked for explosives, timer ect. haha ill be sure to Report
February 6, 201016 yr comment_411501 my 3K is ticking really bad but is full of oil, anybody have any ideas ?? sounds like the tappets are on there way out.. u can get rid of the noise by filling the car up with thicker oil or buying a bottle of that guey stuff that makes your oil thicker from a car shop ultimately the best solution is to get them replaced its not to muuch of a big job |blink| Report
February 6, 201016 yr comment_411507 + 1 For tappet adjustment ,timing chain and tensioner,(fairly common on high milers) Leaking exhaust gasket . Check oil pressure with a gauge.Compression test. rob Edited February 6, 201016 yr by corollaart Report
February 6, 201016 yr Author comment_411511 ok thanks heaps guys, ill be sure to check it all out, thanks heaps again |blink| Report
February 6, 201016 yr comment_411514 A full engine rebuild fixed my ticking sound |blink| and +1 for thicker oil, Castrol have a 25-50w sport edge stuff. Works awesome, even reduced tapet noise on my pajero, and a guy at work swore by it increased oil pressure in his MG Report
February 7, 201016 yr comment_411690 and a guy at work swore by it increased oil pressure in his MG Bahaha MG's cannot hold their oil in their engine's. Increasing the pressure inside just means it will squirt it further outside |blink| Report
February 7, 201016 yr comment_411696 G`day mate, I woulda reckoned on finding out where the "ticking" is coming from before doing anything. Grab a long screw driver and hold it to your ear and start putting the pointy end onto the head, block and other parts. Acts like a stethoscope if you do it right. If you`ve got long hair......look out for the fan. There are a gozillion things that could make that sort of noise so its hard to diagnose anything without a reasonably specific location. Good luck. Old Fellla. p.s. I just hope for your sake that the furkinator spring hasn`t broken. They`re bloody hard to replace. Report
February 7, 201016 yr comment_411700 p.s. I just hope for your sake that the furkinator spring hasn`t broken. They`re bloody hard to replace. +1 for that. If the furkinator spring is broken you may as well chuck your whole engine away and get a brand spanker Report
