thanks re!
update
pulled the head off, off to the machinst soon as i port it for some COMPRESSION
- double valve springs purchased
all bores look good :D
stock cam sorted. off to crow cams tomorrow with the lifters for some grindage :D
still don't think it'll be done by dyno day. sad panda :(
Just picked up a '55 and this is crazy amounts of inspiration!
Can't wait to see how this thing goes on the dyno, keep the good work up!!
I'm almost certain it wont be done by dyno day, so ill be taking brents 5k ke30 up :D
Still undecided on that one evski! I'm tryin to get angybabe to take it!
Update - cam now at crow, $82 for a grind and $40 to get my lifters resurfaced, 3 - 7 power band on a cortina so ill be able to rev it out a bit more without losing power.
if you go down to crow cams don't talk to the older lady. the bloke told me $60 for a regrind and the lady said "$60 is too cheap we can't do that, $82" :glare:
edit - also took the specs for the cam i have in atm. found it in the book "1700 - 3700 powerband" :glare:
Edited by Evan G
ported 3k big port intake manifold, all thats left is to drill and tap the booster line
28mm head scribed with the 30mm intake manifold.
port matched and blended
TEASER PIC no more till its complete :rolls:
Edited by Evan G
Wow, tighe charged me $200 incl postage for my grind. And $5 per lifter to be faced and heat treated. What are the specs on it? Nice work man.
Edited by ae824ate
cheers mang
is that a regrind or did you buy a blank? (semi finished cam?) not to sure on specs, its basically the biggest cam i could regrind, 3-7 grand barp barp barp barp
update
little update, i measured my CC of my combustion camber = 33CC (9.5:1 compression). i needed 31cc to achive my 10:1. my machinist took 25tho off the head, deburred all the cambers, checked out my valve seats. i got the head back today, measured her all up and bang on 31cc :D.
so i got home ready to change my stem seals and swap to double valve springs. also found out 5k stem seals are HUGE compaired to 4k ones and can't be used. fml, so cracked the shits and polished my intake manifold
intake ports have been portmatched and bellmouthed. i went over them with some MEGA course 60grit for more flow.
also found out i have to degree in my camshaft! so i got a camshaft degree kit from ebay for $180, might seam like alot but i have a few camshafts ill need to time so its worth paying a little more.
