Evski's Re55 22R Goodness
  • Replies 398
  • Views 244.2k
  • ill think of one soon :(     probs from the Taiwan seller on ebay
  • $170 for all weatherstrips (incl windscreens)   i got one month rego left on repaired 55, strip it, transfer all the parts to new 55, cut rear gaurds out and most usual spots for rust and keep them
  • Hahahaha but Hendo was Dfunkt's apprentice.lol.   Stu.
Looks like a Bosch Ignition module that they used in Holden Blue and Black 6's Should be good!
Looks like a generic bosch ignition module.
Yep. Just know it as i got the same one in my ute.
Looks good Evan-
How does the oxy meter read??
funny you should ask.
i asked stu (kickn5k) what plugs i should be running with the added compression. he told me a colder range plug, installed colder plug and now shes leaning out in the higher rev. I'm positive its got not enough spark in the higher revs
its out of a xf 250 x flow thing. dads got around 15 of them in the shed
Idle is tough dude but needs more full throttle brap video with straight pipes :P
straight pipe is off. will take it with me to GOR ;).
update
coil in. couldnt get spark out of the igniter.
3 dissy neg
7 dissy pos
15 battery/coil pos
16 coil neg/tacho
went for a drive with just the new coil. WHAT IN THE ʞ©$ɟ! pulls like a school boy again!
it also arc's a 4cm gap and it ʞ©$ɟing big zap aswell
trev what am i do wrong?
Edited by Evan G
3 dissy neg
7 dissy pos
15 battery/coil pos
16 coil neg/tacho
On a 4age 3 goes to dizzy red and 7 goes to dizzy black, you have the polarity around the wrong way.
I tried swapping them around and still nothing. Is there a special coil I need?
I'm currently using a vg coil out of a maxima
ill check if I'm getting 12v to pin 3
Edited by Evan G
Not that I am aware of, I used the standard 4age coil with mine.
tried agian tonight and nothing
used the old coil and nothing
cracked the shits and wired the dissy straight to the coil :y:
Maybe try another ignition module.
ive tried 6. only thing else I'm thinking is the air gap in the dissy?
oh shit, well I dunno what to try on it, maybe even unplug the tacho from the module.
didnt even plug the tacho in. when it was connected it wasnt getting a reading and no spark from the coil
i was getting 12v to pin 16 witch is the neg side of the coil? module got warm
