August 23, 201016 yr comment_461847 i installed a tacho in my ke 35.. its 52mm cheapy where the clock normally goes, its got settings on the back for 4,6,8 cylinder.... its all wired correctly and is set on 4 but appears to be reading double.......idle showing 2,000 rpm and as revs build goes all the way to 7,500rpm to easy.. don't think the 3k will see those revs lmao.... the tach signal ive taken from the - on the coil... been told need to put a resistor on the wire..is so how many ohms?? before i put the resistor on what will happen if i set the tacho at 6 or 8 will that potentially fix the issue? :jamie: Report
August 23, 201016 yr comment_461850 all the switch does it change how many pulses it reads as one revolution. so if its on 4 it will read 4 pulses to 1 rev. if its on 8 it will read 8 pulses per rev. try switching that switch around and see if it gets more accurate? in fact if its reading double, try it on "8". essentially should halve what the tacho is showing if you have it on "4" at the moment. how cheap are we talking here? maybe the switch sticker is wrong?:jamie: also shouldnt need a resistor. Report
August 23, 201016 yr Author comment_461854 yes ill go ahead and try set it on 8... i was thinking it should half the signal doing that but thought id run it by here first... cheap as in $45 off evilbay... but it changes to 8 colors that works great haha..... to bad it don't read right! Report
August 23, 201016 yr comment_461857 It should have come with a small resistor in it's packaging...... When used on a points style ignition system, that little resistor is essential to getting an accurate signal, setting it to 8 will just make it jump around all over the place unless you happen to be particularly lucky.... Have a chat with someone down at somewhere like Autobarns and see if they'll show you the type of resistor that comes with the new ones, the resistor will cost you about 25c from Dick Smiths :jamie: Report
August 23, 201016 yr Author comment_461882 yeh the tach didnt come with any resistor as such.... i will try and set it a 8 see what happens otherwise get the resistor idea going... hopefully someone in here knows the right resistor to use... Report
August 23, 201016 yr comment_461884 i have the exact same problem and am ringing everywhere and they can't tell me what size resistor i need. i have hookd up a saas 2 1/4 inch tach, using gt40r coil. please help!! Report
August 23, 201016 yr Author comment_461894 i just sussed out the online manual for my tacho on the trisco website http://www.trisco.com/manuals/LED%20TACHOMETER.pdf , and it shows it can select between 3,4,6 maybe in asia?... not 4,6,8 as the sticker on my tacho and instructions show...so maybe i got the one with wrong settings... ill will report back what i find when i switch it around.... Edited August 23, 201016 yr by blktoy35 Report
August 23, 201016 yr comment_461979 pardon me but did someone say resistor before toy-yoda? :jamie: i found the resistor that came with my tacho, ill measure it tomorrow and report back! Edited August 23, 201016 yr by Evan G Report
August 23, 201016 yr Author comment_462065 evan g did mention a resistor to me haha.... i had a tinker tonight and switched to the aparent 6 setting and now the tacho idles bang on 1000rpm and revs climb how k engine should....so in my case the tacho is shit may have been packaged as 4,6,8 but is reality 3,4,6....... Report
August 23, 201016 yr comment_462185 I did the clock install thing and had the same problem and now have mine set on 6, which seems to be right. Weird. Report
August 24, 201016 yr comment_462545 Pretty sure i had the same sorta tach in my KE25 (8 colour thingo) had to set it to 6 or 8, i can't remember :) All i remember is that i could swing the needle off the 12,000rpm dial with a 3k. :) Report
August 24, 201016 yr comment_462547 Having a tacho set to 8 on a 4 reading half is a myth, I have found that it is normally the other way around and it was also the cause of a tacho install on ae82.net and a tacho I put in my ke36 did the same (3000rpm idle). ive got it grounded to a part that connects to my ignition but it seems waaay off, its in front of my temp/fuel gauge What do you mean it seems way off? at at about 70 mph it's reading 5k Have you got it on the right setting? i fixed it, it was 8 and not 4cyl I thought it would of been. Grounding can make it read different but the input is what you should check first. Don't worry about a band resistor, just get a variable 'ohm' resistor and that way you can adjust it accordingly, autometer specifies to use one if the tacho has reading difficulties. EDIT: Resistor and fitting guide: http://www.ehow.com/how_5019464_wire-variable-resistor.html Edited August 24, 201016 yr by Trev Report
August 25, 201016 yr Author comment_462636 anyone with this tacho pictured most likley when set on 6 is in fact suitable for 4 cylinder....seems like a few people on here have had this glitch... Report
August 25, 201016 yr comment_462750 Hey guys, i had the same issue with my VW Beetle, loved revving it to like 8000rpm cause it didnt have a resistor, the resistor you need is a rectifier diode. From dick smith its part number is IN4004, or it may be replaced by IN4007. If you keep it out of the engine bay and well insulated itll give you the correct reading on 4 cyl engines. They are cheap as and only take 2-3 days to get delivered if you buy online, which is easier then trying to find a store with them Report
