August 5, 201115 yr comment_544667 oh cr@p i have lost my key at sometime tonight. i have no idea where it is and have looked every where around my house is and its gone. :bash: is there anyway to get a new key cut??? but i don't have a spare key :huh: i didnt get one when i got the car :(!!! Report
August 5, 201115 yr Author comment_544669 no no i mean... is there anyway to get a new one cut,,, i don't mean ffor tonight.. Report
August 5, 201115 yr comment_544672 1 out of 4 corolla keys open other corollas anyway, so just borrow someone elses Report
August 5, 201115 yr comment_544676 1 out of 4 corolla keys open other corollas anyway, so just borrow someone elses It's one thing to open the door. It's another to turn the ignition. PS: Your f@$ked! Edited August 5, 201115 yr by GJM85 Report
August 5, 201115 yr comment_544679 A lock smith???? Call them, they will.come and charge.you about $200. Report
August 5, 201115 yr Author comment_544680 arrrrrr shiiiiiiii^%#TTTT man this sucks so man @ss so what do i have to do now :( new locks. new igintion :bash: Report
August 5, 201115 yr Author comment_544683 A lock smith???? Call them, they will.come and charge.you about $200. will cut me a new key...? because i don't have a spare one to make a copy as i said up the top... :bash: Report
August 5, 201115 yr comment_544686 this happened to me a few years ago, if you can get into your car, i took a barrel to a locksmith to cut a new one, cost 15 bucks. hope this helps Report
August 5, 201115 yr Author comment_544688 this happened to me a few years ago, if you can get into your car, i took a barrel to a locksmith to cut a new one, cost 15 bucks. hope this helps omg thank u so much! i hope it works man. where are u located man?? i can try go to the same one so i know it will work :) Report
August 5, 201115 yr comment_544694 Take your vin number into a toyota dealership and they should be able to give you a ignition key code to suit that car. Then all you have to do is take that code to the locksmiths and they will cut a new key to that code, hope this helps Report
August 5, 201115 yr comment_544697 Just spend 20mins and pull the locking barrel out out the door(easiest one). That's if it's the same as ignition and take it too any local locksmith. My key was too far gone on my ke-11, so I had to take the door lock down so they could cut the key to the barrel. Cost me $80 for two keys. Stu Edited August 8, 201115 yr by kickn5k Report
August 5, 201115 yr comment_544708 There is a code on the small arm between the door lock barrel and the control rod. (or on the barrel itself, can't remember exactly where it is on a KE) Any locksmith worth his salt will be able to cut a key from that code for a few bucks. Edited August 5, 201115 yr by 7shades Report
August 6, 201115 yr Author comment_544824 alright sweet. now all i needa do is actually get in the car... no luck so far :/ Report
August 6, 201115 yr comment_544825 Where do you live? Should be able to do it in under 5 minutes. :) Report
