Alexrx7 Posted October 6, 2011 Report Share Posted October 6, 2011 ive heard it needs to be around 13 14 volts but mynes 12.10 is this normal? also factoring in that my battery is in the boot. any one got the answer? thanks Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted October 6, 2011 Report Share Posted October 6, 2011 12.1v is your battery voltage, so yes, the battery is not charging.. Quote Link to comment Share on other sites More sharing options...
kickn5k Posted October 6, 2011 Report Share Posted October 6, 2011 Dodgey reg? I have/had13.8(battery shop believe that's low) with my KE-70/Holden statesman alt on my 5kze which I'll use again with the 5kte setup. I have the battery in the boot too. What size cable are you using? Stu. Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted October 6, 2011 Report Share Posted October 6, 2011 ideally it should regulate at around 14.3v but that is all dependant on lots of other factors.. Quote Link to comment Share on other sites More sharing options...
Alexrx7 Posted October 6, 2011 Author Report Share Posted October 6, 2011 ive got the charge light wire from the plug on the back of the alternator hooked up to a random 12v ignition source because i couldnt find where to connect it to the light itself could that be a problem??. Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted October 6, 2011 Report Share Posted October 6, 2011 it probably would, yes, put it back to standard.. D+ on the back of the alternator.. Quote Link to comment Share on other sites More sharing options...
ae824ate Posted October 6, 2011 Report Share Posted October 6, 2011 Yeah, as said 13.8V-14.2V is the normal, and ideal charging voltage. "it probably would, yes, put it back to standard.. D+ on the back of the alternator.." And this too. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted October 6, 2011 Report Share Posted October 6, 2011 You do have a chance to set it all on fire..... Don't pick the wrong wire! You'd be better to get an auto electrician to look at it, or get the 4AGE AND the KE70 wiring diagrams and look at them carefully. Quote Link to comment Share on other sites More sharing options...
Alexrx7 Posted October 6, 2011 Author Report Share Posted October 6, 2011 Ive been looking up info and a guy has hooked the charge light wire from the alternator to the positive terminal on the coil as this is an ignition switched source. Does this sound dodgy to anyone? Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted October 7, 2011 Report Share Posted October 7, 2011 its fine if you put a diode in-line with the wire to D+ otherwise when the alternator is still spinning making voltage on D+ the car will try to run on when you turn it off.. Quote Link to comment Share on other sites More sharing options...
Figjam14 Posted October 7, 2011 Report Share Posted October 7, 2011 isnt a battery 12.66V? Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted October 8, 2011 Report Share Posted October 8, 2011 isnt a battery 12.66V? Approximately, yes. The alternator puts out a higher voltage though to charge the battery, usually in the 14V range. Quote Link to comment Share on other sites More sharing options...
Trev Posted October 10, 2011 Report Share Posted October 10, 2011 4age alternator specs are as followed: Rated output: 12V 60A Rotor Coil Resistance: 2.8 - 3.0 Ω Slip Ring Diameter: STD - 14.2 ~ 14.4 mm Limit - 12.8 mm Brush Exposed Length: STD - 10.5 mm Limit - 1.5 mm Regulating Voltage: 13.5 - 15.1 V source: Toyota A series blue book. Quote Link to comment Share on other sites More sharing options...
