Why would you bother doing that when you can just get a TE27 dash cluster from J-land?
Might cost an arm, a leg, or a kidney, but at least it'll look like its meant to be there :)
The other advantage of this style of tacho is a reduction in coil load. As the needle sweeps across the tacho rather than upwards as on the traditional style, the inductive stress on the coil is reduced with a resultant increase in coil output.
As a consequence, engine pickup is improved and top speed increases of 5kph can result.
you've been around too long and every one trusts you. just in case it wasn't clear. these are from the ke2X series. i got that info from the man Peter Robinson himself.
what ever happend to that bloke, is he still around?
Yeah, but you were never going to fall for it
peter Robinson was at the Dandenong All japan Day.
Edit: Mind you I did have to Google "Derp"
Edited by parrot
Tom just wants to be one of the cool kids and fit in the with the 17-25 year old age group, hence even I had to google what the hell the term meant....good one dude!
that is a pretty nifty looking tacho,
i reckon if you put that tacho on top of your dash, and a cop pulled you over and said "WTF is that, its blocking your view, would you like a defect"
you could say, no sir, that is a compass, and it needs to up high so i don't get interference from the steel body.
A compass was standard issue back in 1960, as well as a sextant, but i lost the sextant. GPS's werent invented back then.
