Hey guys
Need help and info for the above mod. Obviously been done before. I realise there are two different clutches and this will be handled once I get the 4 speed out. What other changes will I need to make? crossmember, gearbox mounts ? Anything else that might trip me up?
Thanks guys
Rob
  • Replies 32
Which t50 have you got? There's different shifter positions depending on what car ta22 vs t18/'71/'86
Also the Ta22 and T18 gearbox's have KE corolla output spline count whereas ae71/'86 has a different spline
Back again. Fully recond T50 box has arrived from reputable company in Melbourne. At time of purchase, I explained it was to mate to a 4K engine and it was marketed as a " Corolla T50" , invoice states the same..
Question;
Are there any casting ID numbers on the casing or bellhousing that can help me ID it?
Thanks in advance
I think pictures are gonna help, if you have issues uploading PM me and Ill give you my number and you can SMS me pics and Ill put them up for people.
Sounds like an AE71 T50 which operates off an hydraulic system.
Why the need to a T series box. It will need a serious 4K to overstress a K series box.
For example, in 15 odd years of fast street driving/competition I broke 2 boxes. I was driver error. Slotting 1st gear at 50ish km/h didnt do it much good, but it was still drivable. Second box had a pin in the shifter mechanism break locking it in second gear...... Both of these were behind worked 5K's so the boxes were getting more torque pumped through them than a 4k would grunt out.
If it is going behind something else and I misread the title of the post, then ignore the above, but if you are constantly breaking boxes behind a 4k, it would be easier to modify your driving style..........
