Neg Camber isn't necessarily a good thing on dirt... I know those off road buggies run a bit of positive because it bites in to the dirt better to aid in turning in...
I have no experience with KE's or tuning on dirt so i could be totally wrong :P
Yep your wrong
  • Upvote 1
yeah my dad has modified lower control arms on his rally car :P The camber helps u turn better but also straightens the wheel when u turn so some camber will help ;) Ive even heard of people putting some toe in on the solid diff :P
See ya
Jimi
Slight neg camber is good, but not a whole lot. It really depends on how your tyres are designed to work and what your suspension does as it passes through it's travel. The wheel straightening is more from castor.
See ya
Jimi
Found a big improvement from running slight negative camber from relocated pivot points (and roll centre). Toe out can help with turn in as well but will make the car twitchier to drive.
Modding the diff was the next step on mine - both camber and toe in.
yeah u can always go to much with camber :P
yeah the diff trick is what the old escorts and that did back in the days from mem ;)
See ya
Jimi
I've been thinking roll centers lately. Where about's did you put yours?
Never actually measured it or anything technical, but I'm guessing it would of altered with the relocated front pivot points. They were moved up and out.
PS. Snot and Jimmi - one of you needs to change your pic. I'm confused as hell!
Edited by coln72
I will eventually, I just need a decent shot of the khana car going sideways. We'll get there.
Otherwise, what's wrong with having two twin cam TTE rally cars in one post? I think it's great! :)
