January 23, 201412 yr Author comment_676017 looks like the granny will be getting boosted..... got turbo setup.. got head, got push rods, getting lifters... just need 5k bottom end.... Can anyone help?? hoping for 80-100rwkw... but will be running standard 4 speed and diff.. so i don't have to chop or do anything stupid.. Report
February 3, 201412 yr Author comment_676774 heres a little picture of the time bomb 4k ill be wacking in until i find a 5k bottom end.. just need a few things before i start fitting it.. Report
February 12, 201412 yr Author comment_677355 Slowly getting bits done.. Decided to run an elec fuel pump rather than standard. Got regulator and pressure gauge sitting in bay ready for motor install.. Also got my oil feed line today.. Just waiting on my pump and have to get someone to weld in a return line in my sump. Then in she goes.. Then bang she goes.. But hope it last till I build the 5k Report
February 12, 201412 yr comment_677360 How high does the turbo sit? If high enough you could make a blank off plate for the fuel pump and tap a return fitting into that! Don't want it up hill though. Report
February 12, 201412 yr Author comment_677401 Pretty sure turbo is higher than fuel pump. I'll look into that but where the return line faces it may be easier to go to sump.. Will have to have a look today, thanks for the idea Report
February 14, 201412 yr comment_677522 thats cool, goodluck with keeping it together haha cheers darren Edited February 14, 201412 yr by untubbed_20 Report
March 2, 201412 yr Author comment_678629 motor sitting in engine bay.. need some 4k gearbox bolts as my K bolts have a different thread, and need some allen key bolts so i can mount my manifold.. Hopefully my MSD 6BTM will arrive soon also... slowly getting there. Report
March 13, 201412 yr Author comment_679345 taken it around the block yesterday with exhaust finishing around the firewall.. Couldnt rev it hard as the neighbours may get upset .... boost gauge didnt show any boost? could this be the lack of back pressure? not revving hard enough?? maybe screwed turbo? can hear it spool but showing nothing.... if its a t2 hi flow any idea what sort of revs i should see psi? atlest it sounds cool now :) https://www.facebook...443372203971528 just happy it moves at the moment.. i had my doubts Edited March 13, 201412 yr by rke_011 Report
March 13, 201412 yr comment_679357 Try again and either rev it a bit harder our load it up a bit more in a higher gear. I'd imagine with a t2 you should be seeing boost pretty early. Report
March 13, 201412 yr comment_679365 could this be the lack of back pressure? no back pressure after the turbo is the best thing for a turbo so thats not the problem sounds like a silly question but is the boost gauge hooked up right to a boosted pipe? try braking and accelerating at the same time to load it up and make some boost without flying up the road Report
March 24, 201412 yr Author comment_680010 Boost gauge is connected in the cross over pipe from the inlet manifold to turbo.. So it should be OK... Only thing I can think of is that its making boost but possibly because there is fuel in the boost line it is blocking flow to the gauge? I'd assume the pressure would bypass the fuel.. But I dunno.. Need to take it for a drive again.. But can't be farked moving the wife's escort out the way.. Report
December 29, 201411 yr Author comment_692324 4k turbo 1967 ke10 Corolla: Cleaning cob webs out.. still needs an exhaust.. been lazy.. I did see a tiny 3psi :( need more boost and a fuel pressure regulator.. standard pump is flooding carby... Edited December 29, 201411 yr by rke_011 Report
February 6, 201511 yr Author comment_693887 Exhaust was installed yesterday... A little silent... but 2.5" so flow should be fine... shows 10psi now and seems to move quite well... better than the old K :) should be keeping up with traffic a little better now Report
April 19, 201511 yr Author comment_696339 After a month or so of driving I'm looking into the future.... And future looks like I need efi and more boost Time to start collecting bits Report
