Nicks Ke30 V6 Project
I have already fitted the Intank EFI fuel pump from the VN in to a spare fuel tank i had ready and will fit that tomorrow too.
Does that accually work? I would've thought youd get fuel surge at lower tank levels?
  • Replies 191
  • Views 224.6k
  • i really like ur port a wall tyres they look so good. i will get myself when i find a ke35 or 55 car very soon.
you are right, yes i will have problems with it fuel surge. Ill have to make sure i have plenty of fuel in the car, Main use for this car is the burnout comps so lots of fuel going to one side to the other in the tank, I think that maybe ill make this pump the surge tank lifter and use another pump in the boot. Bit tight on the budget so i just want to get it up and running first.
sweet does it run yet?
yeah man thats looking cool u going to go to the drags when its all in
its no running yet, I'm waiting on a bellhousing, But I'm holding off at the moment as we have a car swap meet coming up and there is always mostly holden and ford shit there.
so maybe i might pick up a v6 manual gearbox or something.right now it got a 4k back in it and ill tidy it up and try to rego it.
I will be using this car for burnout comps and drags, when they run the drag meetings here at the end they run burnout comps
oh ok that was only a test fit it should do well in the burnout comps
i cannot see pictures
looking good there, whos is the white ke70/ae71 in the background?
:P looking good man
would it be legal to get it registered with 17's?
i don't see why they would be illegal, i think in tassie you can just run what ever wheels you want
you should paint the bonnet black, the car is looking great, what exhaust are you running, gunna lower it????
