Battery In Boot Project
Thanks for the picture, i ended up buying a junction box.
Cheers, Rob
  • Replies 33
  • Views 49.2k
Buy a sealed battey and then you don't need to worry about it, Dunno what will happen if you don't vent it.
Hi,
If the battery isn't vented A it makes gas and well will make pressure and possibly blow the sealed container it is in up.
Also Battery's make Hydrogen :) This is highly flammable so if you want to turn your car intot eh hindenburg put a non sealed battery in a box it will build up one small spark and good by corolla.
So it is purely to vent the flammable gases coming off it.
Cameron
get an odyssey battery - fully sealed and fully sic bro.
where do you get 250/300 fuses?
Ive been to Jaycar/Repco/Auto One and have had no luck.
thanks
thanks
Your local auto electrian might have a few.
jaycar has 12v circut breakers around that range
just had a quick squiz at their website ... 120 Amp is the best they can do.
hmmmm
Slapper
Cam you can have a look at my brothers setup when you come over tomorrow.
I'm in the middle of relocating my battery to my boot, but it wont earth to anything in the boot
any ideas?
what do you mean "it won't earth" ?
You need to expose some bare metal and bolt an earth cable to it - use a coupla star washers and a decent bolt ...
Look at the earth cables in your engine bay ... you'll need at least that size.
does that help?
Slapper
