Yup, some people think that Holly's are the next best thing since sliced bread. Re: some Commodore drivers.
Lets all play "drown the 4K" :)
If youre gonna go to that much work modifying a manifold. Might as well go side draft. :)
  • Replies 44
wtf tho there massive it would like down the whole thing and then the spark plug might decide to spark and blow the whole thing too bits,
back on topic i have found 2 brand new 1.5 su's for $150 on ebay(bidding hasent started but) iv offerd him $200 but chances are very slim so...
su's are way better than standards but no-where near as good as twin webbers. look at the firing order 1-3-4-2 so the 1st pulse comes off the first carb then the 2nd off the second carb and then the 3rd off the second carb aswell and the 4th off the first carb.
i know that only one cyclinder is being used at a time but at high revs your bound to loose performance compared to twin webber where each port gets its own supply of air+fuel.
that head didnt sell i think, it had gemini valves in it, it was started at $500 but no one bid on it, you could contact the owner somehow, he is in devenport, he also had a ke10 forsale
cheers james
hey wilhav1kikassrolla,
as much as you are keen about this little project, getting twin carbys on your car may be a little quicker if its k motor manifold you want, :y:
as i have a twin carby manifold with linkages just sitting in the shed . ;)
i will try get some pics over the weekend, may help you out for your set up fabrication or for the right price i may sell it!
cheers adam
ill have a look but I'm pretty sure I'm buying a ta22/ra23 this weekend
with a 2tg (twin solex webers) i would be glad to look tho thanks casey
:y: silly bugger wants over $1000 for a dirty old ra23 without wheels stuff that, looks like rolla20 might be lucky
thanks casey;)
here you go matey,
this next photo is of the bottom ,where its meant to bolt up to standard exhaust manifold , but it broke so i cut it off,
so extractors would be good for this .
if you want it, name a price
and i might just sell it!! :y:
cheers adam
May want to weld up the hole in the bottom as I'm pretty sure that it links the two carbies together. I don't like the idea of fuel mixture spraying onto my nice hot extractors.........
nah remember theres a little plate that seperates the inlet from the outlet I'm guessing the air would go up in thewre to heat it up and make it warm up quicker
nah coln72 ,
the hole that is cut out is i think for a water way which heats it up , but I'm yet to find the head that has the water outlet for it , but there is the balace tube between the two carbys which is untouched.
cheers adam
willhav1kikassrolla PM sent
Edited by rolla20
nah coln72 ,
oops me bad :lock: forgot about water heating.
yeah stuff buying stuff is you have no money, and makin stuff is so mutch more fun ( sometimes) LOL, another thing you could do is make one from scratch and make it out of mild steal, then tha carbys will sit lower to cos you are not runing it onto of the origanal manifold.
so make ya runins out of some sort of pipe, and make to bass plates and put it all together,
I'm goin to make my own sidedraught manifold for the 3t in my ke20, cos got no dosh to buy one, and will be easy as.
i just love crazy ideas.
Cheers, dan
