September 22, 200620 yr Author comment_142373 thanks tas, i have done 1 hotwire allready and ill post pics up asap I'm painting all the "wires" and the center bits looks pretty good considering the use of $2.50 paint I'm going to clear coat them aswell. off to get a mothers power ball thismorning Report
September 22, 200620 yr comment_142374 sounds pretty good, ke10/ke20's are 110pcd and cortinas and escorts are 108pcd, they will fit but are pretty dodgey Report
September 22, 200620 yr Author comment_142426 oh well, my plan in the near future is to get a ke10 or 20 of some discription, just clear coated 1 wheel and its looking realy snazzy. i brought a polishing tip for my drill at rare spairs and it was like $16.35, pretty bloody dear Report
September 22, 200620 yr comment_142430 what do you mean by "polishing tip"??? if its sort of like a die grinder bit, then you could create yourself more work than you save if you take the smooth finish off it!! best way to get a nice polished finish is with wet and dry sand paper, getting finer and finer and then a bit of a polish after that. REMEMBER - The high gloss finish you maybe after will always be more so from wet sanding that what you will ever actually get from a tin/tube of polish. Report
September 22, 200620 yr Author comment_142440 just a drill bit style thingo, and yes i have started on a rough grade sand paper going to a finer one then to steel wool then to polishing by hand then to the drill bit Report
September 22, 200620 yr comment_142458 I think he means he has some sort of polishing/wool pad for his drill... yes/no casey? Report
September 23, 200620 yr comment_142593 yea the polishing tip didnt work as well as he wanted it to, but shined the part of his wheel that he did with it really nicely Report
September 23, 200620 yr Author comment_142617 just my current selection Edited September 23, 200620 yr by casey Report
September 23, 200620 yr comment_142621 Wow they're shiney. I tried that Autosol stuff with steel wool on my Longchamp XR4's but they didn't come up overly well. I'll have to try the sanding. Report
September 23, 200620 yr Author comment_142635 i used "turco metal polish" first up we cleaned them with "amway" metal cleaner then sanded them right back with roughish sand paper then with smother stuff then steel wool then polish on the steel wool then polish on a rag then polish on the "drill bit" still allot to go the results are rewarding tho Report
September 23, 200620 yr comment_142651 yea the more work you put in with the sandpaper the better your results will be, i would also recomend using "autosol" polish is usually more expensive but it works really well, patience is the key and alot of elbow greece.....god damn i wish you could get it in a can (personal joke between casey and i) Report
