this set of rims are 1983 vintage , so period correct !
welded because if SSR Work etc deem they need to be from their factory
then i feel they should be from mE
I do wheels for my self first and foremost , so why would i want to cut corners to save a few bucks?
it's like rebuilding your engine and deciding the old head gasket will be alright .
These Southernways were not originally welded together, and Simmons are not welded either so its not really a legality issue,
the weld increases the strength of the rim, helps with sealing and is good for added safety
a little extra cost is minimal compared to the carnage that could ensue. after all you are relying on 20 6 or 8 mm 6.6
high tensile bolts and nuts
same as bolts , why re use 20 + yr old bolts when for around $80 you can buy new bolts and nuts at a much higher grade
i use aviation grade 12.9 high tensile bolts as i have snapped a standard ssr bolt in a rim once .
t'was fun running down the quarter , i only need to find 6 seconds and then it will be a race :blinks:
