mungi mods
    840
    3
Everything posted by mungi mods
  1. rather than building a boosted k motor , just do a 4age/ze conversion its relatively easy and cheap , easy to legalise and then can be boosted later it wouldnt be that different in cost plus a stock smallport would probably make the same hp anyway + REVS
  2. went for a little drive with Matt , car sounds awesome Quads. FTW how were the two HOMO"S Matt? wankers
  3. ebay >no :( fit em on a ke70 in a day > i could :)
  4. 17' on a rolla only if they are like these.. 17 x 10 0 offset
  5. clear brakes no problem? look good on there :) you need to remove the new tyre stickers
  6. A LITTLE ROLL and she'll be SWEET !!!
  7. WE ARE AWAITING THOSE ON THE CAR PICS mATT
  8. 2 x new 6061 heat treated outers , welded , polished , valved and tyred :P now awaiting fitment :abuse: other pair are getting welded now coming to a 20v ae71 soon :D should fit under 100% *e7* stock guards with 205/50/15's..................
  9. where's the rest.. :D
  10. ke70 front hubs and ke30-35 axles with 5mm cut off = 4 x 114.3 conversion , all bolts into a ke20 uses factory front discs and calipers and backing plates, gives you bigger rear brakes drums too then 15 x 7.5 0 offset rear and 15 x 7 0 front with a 185/45/15 tyres = standard ke20 12 inch rim n tyre rolling diameters DONE
  11. next Wednesday night test n tune is 23 June 2010 lets see if we can organise a good roll up for this.. 3 weeks notice should be enough for everyone
  12. I'm going, will be video camera-ing too both in car and outside car :D
  13. I'm in, hopefully with fresh rolling stock on board by then
  14. no probs nizlah
  15. rays mesh now sold and off the car :lolcry: now sporting heroes racing 15 x9 0 offset rears :dance: and the trusty red 15 x 7.5 +2 offset advans on the front ::blush: : new and improved rims are in the works :blinks: also toying with doing some "specials" for this , flouro green lips with Chrome centres, just for shits n giggles :blinks:
  16. nuff said.. 15 x8 -6 offset southernways mesh :happy: made 11/83 modified 5/10 :huh: 3 to go :yes:
  17. everything is for sale.. for a price i think the current set of rims are sold anyway , just waiting on a test fit
  18. 205/50 brad.. na, running under the radar , doing the blend in thing :happy:
  19. this will be getting alot wider soon just waiting on another set of rims to be completed ( 15 x 9.5 front 15 x 10.5 rear ) :happy: guards will be flared to suit and then new paint will be xt130 front soon also, with coilovers and camber, as it needs more low in the front rear chassis rails are soon to be removed and replaced with chassis bracing inside the tray so rear can be 1 inch lower also it's a work very much in progress and will not suit everyones tastes, but the only person who's "vision" i want to achieve is mine Kamei lip now has 2 40,000 lumien orange LED's mounted in the leading edge .:yes:
  20. buy one then ,,, yep it is the same van, gimme a call and come measure it up if you want i have splits on the doors, which is much bettter !!!
  21. why mini tubs? what size rim and tyre you looking to fit? i have done a ke , all factory steel with 15 x 10 -27 all round with 205/50/15 @ 70mm ground clearance with the right offset a ke70will take a 10 and 225 easily
  22. buy here :happy: http://www.rollaclub.com/board/index.php?showtopic=38413
  23. lip, low, fat offset's = street cred on a *e7*
  24. i reset my leaves 4 inches and i am still 140mm off the ground , minimum is 100 mm... are the ssr s , star formula or ex-c's?
  25. lip has 105mm clearance to ground ;) Buy a Kamei Lip = instant coolness =) see LittleRedSpirit soon or they will all be sold out 8S I'm buying another one for Rory the racecar .. :D
