Everything posted by mungi mods
Explode Your Brain Helping Me
geometry is different left toright and the lca stamping is different to help with geometry
Ke70 Exhaust Best Way To Achieve A Top Sound
mine retains standard manifold and front pipe to hotdog then 2.5 to hotdog the diff into twin 2.5 pipes out the back total cost was $10... performance is the same ( crap) doesnt sound like a 4k = win
Jdm Style Tuning Meet
was last night .. Monday night 21/2/11
twin rear half in a 2.5 inch will make it a deeper note 2 hotdogs
sounds like left n right lcas are on the wrong side of the car..... check again ... they are not the same , and the steering arm can be rotated 180 degrees so would look correct
Ms55
these are the new wheels for this......:wink: 5 x 114.3 15x ???? -6 i'll let you fill in the blanks :yes:
- Ms55
Daniella The Delivery
- Explode Your Brain Helping Me
crosmember different ? ra40 rack end tubes are longer- Explode Your Brain Helping Me
what Lca's are they? if they are xt130/sigma problem will be the tie rod tube is too short , from memoery ra40 tie rod tubes are longer allowing you to move the tie rod end out to correct original car may have these already, or it may have a lock spacer .try changing the complete rack over fyi i run maxxed castor on mine and it is perfect, still havent done a wheel alignment and its been that way since i first got it.- Ra60 Celica - Beams 3Sge + 5Sp Auto
corona mk2 f series diff nice n short (ke70 length) just convert front sheet metal/lights n bar to *a65 pics ............ I jz is a better option :wink:- The Red Baron Ke25
- 20v Into Ae71.
polish then clear powdercoat silver sparkle 2 powdercoat- Which Model Corona For Strut Conversion?
xt 130- 72 Ke20 Cruiser
front needs more low when i had mine it was reset 4 inches lower with reversed eyes and an extra leaf :yes: i shortened the bumpstops in mine :lol:- Jdm Style Tuning Meet
[QLD] JDMST Meet February 2011 | Brisbane Hey guys, next meet is Monday, 21 February 2011, 8:00pm. Location is Brett's Hardware carpark, Newmarket Rd, Windsor.- Daniella The Delivery
in tech articles is my guard flaring thread http://www.rollaclub.com/board/topic/29887-tech-articlehow-to-flare-front-guards/- Daniella The Delivery
android double post 15 x 10 -12 work ewing mesh are also finished and chillin in the garage- Daniella The Delivery
Silver top over the original green Front bar when and if I find one- Delete
yup w57 off compliance plates t series diff = T-312 3.9-1 ratio- Timbo'S Ae86
JHH head services at woodridge did my smallport head, mild port/polish 3 angle valve job ,full recondition , picked up around 15% with stock cams etc. mine was on carbs though and no factory limiter...- Delete
pics with other cover fitted so today i have removed all the bump strips, tailights and rear garnish, rear bar and towbar all boot lining and wiring in readiness for rust removal and plating and weld filling all unnessecary holes this thing has soo much bracing and strengthening in . the rear has a 50 x 25 boxed crossbrace into the rear inner arch which are reinforced with 4mm plate cabin side of boot floor is also reinforced with 4mm plate and 50 x 25 box section b pillar is reinforced as well with 4mm angle which has sections going rearward to the crossbracing as well. will post some pics soon oh also it is now a runner, the stock 21rc is healthy as is the stock w57 with short shifter clutch seems good too, factory fitted t series isok as well. plan is fix , paint,rego then will start the 1jz conversion- Tyre Fitment
ke20 is 4 x 110..............- Delete
Will be ra65 or ga61 front- Timbo'S Ae86
got wheels here for you to test fit tim talk to Matt when your ready... - Explode Your Brain Helping Me
