Everything posted by SLO-030
Ke20 4K Twin Webbers
3 x 14mm nuts on the top of the strut tower 2 x 19mm bolts that hold the strut to the steering arm. 2 x 14 or 17 mm bolts that hold the caliper to the backing plate. Tip, Remove the little clip that holds the brake line to the strut, and slit the littel bracket so you don't have to disconnect the brake lines for the calipers.
Random Photo Thread
Thats f@$ked.
Spotted
There's a Blue KE36 that gets around the Hallet Cove/Lonsdale area. Not Scotty's 26 tho. Spotted a White KE25 on South Rd, bedford park approx 7:30am, Tint, Exhaust. Looked pretty clean.
--------{Ke38 Wagon}---------
Chris, Hope to see your KE38 on the 2012 GOR trip!
Greenmacs Other Ke!!
Congrats dude! Sparks sound like the flywheel hitting the adaptop plate. Check clearances when you pull the motor out.
Swapping Steering Arms Left To Right, On Ke70 With Ra65 Struts
Can't have a local suspension joint tweak/bend the bottom of the struts? What setup are you running on the 65 struts? There are a few sets of XT130 struts for sale up in QLD in Toymods..
Slo-038 + 10Psi
I'm sure whatever you get will be sick..
Spencers Ke70 Touge Street Fighter
99% are Flat top piston. The dished piston ones are refered to as 4K-U. Dished pistons denoted by the tabs under the 1st and 4th spark plug tube as per dished piston 5K's
Slo-038 + 10Psi
All good man, figured you'd be a little dev about selling on the 20. Chin up, maybe a KE1x? :P
We tried this in Greenmac80's KE30 with MX62 struts and RA65 steering arms. It ended up putting the balljoints and tie rod ends on a shithouse angle...
Slo-038 + 10Psi
Least you need to replace stuff for a worthwhile reason....
- Slo-038 + 10Psi
Wheel Varnish Help
Try some 320 double sided foam pads, removed the clear coat on my challengers really well.
Slo-038 + 10Psi
Evski, Hows about you send me down a 4.3:1 Borgie, Kthanks. One of the caps had half of the roller bearings smashed, mixed with grease to make some metalic sludge. Another GMB fitted, see how long she lasts....Now taking bets... :P
Spotted
Spotted you Scotty last week at some point, along Blacks Rd.
Herbert The Panel Van
Congrats on getting the hoist up and running. Is that a pair of swaybar links and bushes i spot?
Slo-038 + 10Psi
No shit ey. Thinking about buying shares in Hardy Spicer and GMB
Slo-038 + 10Psi
Yea, getting under there with a tape measure to see whats causing it all. Never had a problem with the Borg setup....
Joshs Ke36 Panelvan Project.
Great to see Ollie is progressing well now. Not long to go boys.
Slo-038 + 10Psi
Annnnd, another rear uni. FML. Need to get the back end in this checked out, Diff is sitting over toward the drivers side a bit. Not sure whats going on there.
Spotted
Spotted a white KE36/38 wagon in Unley tonight, Parked just off of Cross Rd.
What Grinds My Gears.
Like Reed said, use it as fuel to prove him wrong :yes:
Borg Or Jap
No, thats the Uni Joints. On average of 1 uni/wk Going Borgy, for the fact i can use a massively bigger tailshaft, with bigger (Holden 6cyl) uni joints, and the tailshaft will work with the W50 thats going in.
Borg Or Jap
Depends on the Model of diff in comaprison in the Strength detbate.
Slo-038 + 10Psi
Cheers Bro! Wouldn't have happened if it weren't for a big number of people that have helped along the way! On a darker note. Have broken something. Not sure what it is, but its not how it should be. If anyone has a 4.3:1 Late KE30 or KE55 Borg Warner diff in good condition, please let me know asap.
