KeelzaMate
Everything posted by KeelzaMate
  1. Nah I don't, but when I get a chance I'll bolt a ke55 crossmember to it on the stand and take a pic.
  2. Plenty of room for the sump and oil filter. My 4age ke55 engine mounts using ae86/71 rubber mounts, quickly bolted on my spare motor.
  3. as for engine mounts, cut and shortened ae86/71 mounts should work fine or custom brackets with ae86/71 rubbers. 16v and 20v have different exhaust flanges.
  4. 2.5inch i believe.
  5. http://www.ajps.com.au/parts/kelway_turbo_manifolds.asp
  6. Jim Berry or NPC
  7. So it's been around the block.
  8. if ur running a standard ecu, ud have to run a controller, but I'm running a microtech so ill run it off that.
  9. i know I'm not gonna get massive power gains but i don't think it will be worth 3-5hp gain compared to a 20+hp gain, i test it out with my mates one before i buy one an see how much difference it makes.
  10. Electric Water Pump on a 4agte, is it worth the power gains or just stick with the standard mechanical pump?
  11. I'm trying to think how you could run it without running it first into the small to the big turbo, you couldnt run the small turbo off two cylinders and the big turbo off two cylinder cause that will throw out the cylinders, maybe have all four cylinder supplying both turbos and the small one will spool first and the bigger one will take over in the high end. maybe for a 4age, a t28 (small turbo) and gt30 or gt35 (big turbo).
  12. thats the one :jamie:
  13. twin t28 i reckon or a small turbo for low end and a big turbo for high end
  14. my mate got his tailshaft modified for his hilux diff conversion at Gibbs Trucks, they are on the gold coast
  15. the oil filter didnt foul the stud, sat just aboove, id put a pic up if i could find the usb cord for my camera.
  16. Mine are custom ones with ae86 rubber, currently doing engineering drawings of them seeing ive got the motor out. Cheers, Keelan
  17. If calculations are correct: The bottom angle should be: = 40.36 degrees And the top angle should be: = 139.64 degrees
  18. KeelzaMate replied to 1JZKe55's topic in Rollaclub Rides
    oh its standard officer :blush: looking sweet as mate
