dbr11k
    1086
    2
Everything posted by dbr11k
  1. was going to post this somewhere else but wasn't sure where lol.. hopefully i get some reply's.. i was just wondering what is the go with track days? is there any drift events that i can go to in nsw that don't require the car to be registered ? and also do i have to be licensed to enter the event ? or am i just dreaming here ? only reason i'm not registering this car is it's going to cost me thousands to get it on the road, engineers cert, blue slip, any repairs that might need doing, and also i won't have a licence for another year :fuzz: and here is a pic of sway for the sake of it .. the ke55 in the back ground is still for sale, just needs paint and body work done, no major rust..
  2. hell yea this thing is awesome !
  3. sick two door mate i want one !!
  4. yea i was wishing i had money cause there is a wolf 3d mapped to run a silvertop on ebay atm and its cheap as chips :( and also i'm getting a hydraulic handbrake eventually :yes:
  5. haha thanks mate .. it goes hard as and sounds amazing .. just needs the brakes bled cos it doesnt like stopping :glare:
  6. picked this up just the other day .. i dub her 'sway' .. needs a little bit of tlc but will make a sick little slider when i'm done with it ! :cool: it already has an adjustable panhard, trd shocks in the rear, ae86 struts, strut brace etc .. plans are to not have a single piece of the suspension setup left standard.. will keep pics updated as it comes along. let me know what you's think. heres an up to date list of whats done to the shit box, front suspension: Ae86 ajps coil over sleeve kit Ebach 8kg springs Koni shocks Willwood 4 pot callipers Willwood 288mm slotted & Cross drilled discs Willwood Full race pads -3 Steel braid teflon brake lines T3 extended adjustable tie rod ends T3 roll centre adjusters T3 shortened knuckles Ajps lock spacer superpro rack bushes new rack ends T3 rose jointed adjustable lower control arms T3 rose jointed caster arms Cusco camber tops Cusco strut brace cusco lowered engine mounts cusco gbox mount Rear suspension: F series diff with Lexus TRD 2way LSD Modified diff mounts with welded traction brackets Custom 6061 alloy CNC Machined caliper brackets twin r33 skyline calipers speedflow -3 braided brake lines T3 rose jointed adjustable 4link trailing arms T3 rose jointed adjustable panhard Whiteline 19mm blade adjustable sway bar 6kg ajps springs ajps height adjustable spring perches Trd blue 8way adjustable short stroke shocks body: sheet metal floor front inner guards replaced with 48mm tube front custom tube lower radiator support 4 bonnet pins welded in engine bay custom quad headlight brackets shaved front indicators shaved antenna shaved front door handles with pop button on sill Flat front with DX quad lights shaved fuel flap front in rear flares rolled and pumped flares rear doors welded shut rear door hinges welded rear door handles shaved sheet metal 'ute tub' sheet metal rear firewall deleted A pillar gutters smoothed custom shaped B pillars 48mm CDS tube bracing between B & C pillars bracing between spring perches and C pillars bracing between rear chassis rails Isuzu dmax rear tailgate welded solid probond composite sheet hard tonneau 4 point roll cage seam welded bay and chassis interior: sound deadener stripped interior battery mounted passenger footwell 2 bucketseats takata harness alloy dash board speco gauges battery isolation switch shortened steering column cheap drift wheel quick release boss Willwood hydro handbrake master cylinder Willwood brake bias adjuster custom hydraulic handbrake lever 40lt fuel cell dropped 1.5 litre surge tank Bosch 044 carter silver series lift pump mounted under car running through interior > speedflow -8 fuel feed speedflow -6 fuel return speedflow -4 hydraulic handbrake speedflow -4 rear brake line bulkhead fittings throughout driveline: Airies pistons ZE rods Arp rod bolts Arp main studs Arp head studs Cometic head gasket Reconditioned cylinder head Custom GCG built GT28 66 spl roller bearing turbo 38 mm tial waste gate, Screamer pipe 3 inch dump pipe custom steam pipe manifold 700cc sard injectors Blacktop individual throttle bodies Custom Hypertune plenum Custom Hypertune intercooler Custom Hypertune intercooler pipes Custom Hypertune alloy radiator/oil cooler combo 2 x 10 inch thermo fans, custom sealed shroud Custom Hypertune header tank/ water distribution setup Custom Hypertune Rad overflow/Oil catch tank Grex sandwich block to suit oil cooler Grex Thermo oil re route block Steel braid hose & Speed Flow Fittings throughout Extreme 5 puck ceramic clutch Extreme 3.9kg flywheel knight parts bell housing reconditioned Steel plate W58 supra twin turbo gear box Custom ae71 Gearbox x member Custom one piece 3 inch tail shaft hardy spicer joints Haltech E8 computer LS1 coils mounted under dash Tuned By JEM shoes and socks: 2 sets of 16x8 rota grid (rays te72 copy's) -4? offset nitto nt555 current pics
  7. the new toy (: 20v ae71.. have heaps of parts in the shed ready to go in her :cool:
  8. Hey all just wondering what some people out there are doing with their 20v 4age's spark plug cover. mine is missing and i can't find one for sale anywhere, does anybody know where to get something like, this?
  9. ENGINE CONVERSION WILL BE ILLEGAL ??? AAAAAHHHH !!!! >| >| >| >| lol just kiddin.
  10. yea but now she can pay for it :lolcry:
  11. Maybe try putting it in Falcon terms next time? The retards usually understand Ford talk a bit better :rolls:
  12. So anyways, I heard it through word of mouth, So my guess is it's just a load of School holidays bullshit..
  13. Ok so in a strange twist this thing is now sold .. To Sammy :hmm: lol. She wouldn't let me sell cause she originally wanted to buy it before I did.. So I said fine you buy it than, And that she did! And I have purchased another project with the money I got from selling Rosie, pics to come soon, I think alot of you would have already seen this thing :cool:
  14. awesome stuff can't wait to see this thing in action !!
  15. everyone out on school holiday i guess :glare: !! haha
  16. anybody heard anything about this? apparently it will be illegal to do engine conversions as of the 28th of september???
  17. carpet in
  18. thought i may as well keep this alive .. half finished in my ke55
  19. I live in nsw haha.. about 2 hours from canberra
  20. i know i know but i need the money .. if it doesnt sell by this friday than i'm going to keep it.
  21. unfortunately this thing is now up for sale in the for sale thread.. i need money urgently.
  22. black would look pretty good imo
  23. ouch. that sucks :n:
  24. nooope .. been having too much fun loving life haha, hunting, riding and camping.. but have been ordering a few things for it.. got new carpet ready to put in, got a HID kit for it and some modern head lights.. gotta pull my finger outta my arse anyways cause it's nearly time for rego.
