anastasios
    1006
Everything posted by anastasios
  1. hhmm i don't think you should bother with them
  2. just go to an exhaust shop, they will have tips there and give you a hand on what to pick.
  3. i need more photos of the linkages, what parts were used and how they connect to the throttle and carby
  4. yea sounds like a good deal, engine must go well, if i was you id take it to a carby specialist to take a look at it before you start fiddling with things, it depends what your budget is, don't go to a single weber
  5. does a ke70 even have a torque convertor?
  6. plus its pointless, just don't kill your 2a
  7. na don't get superlites, get something more jap, the superlites are more old euro style, it doesnt totally work, if i was you id get some longchamps or mark 1s
  8. ok well it started, i took out the fuel pump and sucked some fuel up into it and its all good, i got the engine running with some oil flush to get rid of the oil and i noticed a leak from behind the pump, so i took it off and that spacer is cracked in two, are these available new?
  9. does your pump have a return line on the pump like my one? as seen in the first pic?
  10. Hey guys i have a 4k in my 70 and had it running, it then decided to stop pumping fuel, i realised i didnt have the spacer between the pump and the block on so i put that on with a new pump and gaskets and i have a return line on the pump going back. Should fuel squirt out when i crank it over? or does it need to be connected to the carb so it creates a vaccum, there is not much fuel in the filter at all. i have a downdraught holley 26 27 and was also wondering which fitting was for the inlet and where do i connect the return to?
  11. ok well ive put the spacer on as well as a new pump and gaskets, and when i go to start it its doing the same thing, the fuel filter has barely any fuel in it as well, any ideas?
  12. anastasios
    Over.
    crashed it before the respray?
  13. yea because randomly the pump stoped pumping yesterday as i was going to start her up, ill take a look into it, could it be the fuel filter?
  14. is there supposed to be a spacer between the block and the fuel pump on a ke70?
  15. they both look shit, don't do it
  16. whos the organiser for sydney?
  17. go optus, do u want a prepaid or plan?
  18. why don't ya try and find a tacho dash? make it look more cleaner
  19. i hope they don't make any! those ones on ebay arent really aftermarket, you want like autosalon altezza styles? don't worry about it i rekon they look silly
  20. it all depends on your budget mate, and this has been covered in the above posts
  21. I'm not here to compare our cars thats what children do, our cars are different styles if its always people saying how good a car is we don't get any improvement or change, I'm not scared to give my opinion and can handle the abuse, someone has to do it, i would like to see some quality jap style cars as i think it brings maturity, for example jdmstyletunings forum i havent seen a sydney corolla cruise on here for ages mods delete what u want outa this thread but I'm sick of rollaclub not going anywhere
  22. nice respray and wheels man, I'm not too sure about the pinstriping or the cannon though, is there a noticeable power difference? did you try it on normal fuel?
