anastasios
    1006
Everything posted by anastasios
  1. But the above diagram shows the 0.5 fusible link between the battery and efi fuse?
  2. What wire do you recommend I use from the fusible link to the relay?
  3. Okay so I have found out it is a fusible link, does anybody know where I could get this one?
  4. What is the 0.5G between the battery and 15A EFI on the corolla wiring diagram?
  5. any chance with that diagram?
  6. thanks mate, I'm in no rush, at work myself lol!
  7. So do i not use my COR?
  8. White/Red - Wires to EFI Relay - +12v Ignition Switched power (Run through a suitably sized fuse, 10A is usually fine, but depends on your fuel pump). this confuses me
  9. Hi all, I've been away from rollaclub for a while, at the moment I am building an AE71 with JDM bigport and JDM fuel tank. I am stuck with too much confusing information regarding the wiring. I have a circuit opening relay. I have one of these http://www.jaycar.com.au/productView.asp?ID=SY4076&CATID=79&form=CAT2&SUBCATID=979#1 And i need to know how to make it all work Ive grounded the earth wire from the fuel pump in the boot I also came across this: White/Black - Wires to to STA - Starter/ECU Start Signal. White/Red - Wires to EFI Relay - +12v Ignition Switched power (Run through a suitably sized fuse, 10A is usually fine, but depends on your fuel pump). Green - Wires to engine run signal - "FC" pin on 4AGE ECU. Black - Wires to body earth - Wire to closest earth point. Blue/Black - Wire to fuel pump positive - Gives power to your fuel pump. One guy from 86DC said this: The efi main relay is just a regular relay. The oem one isn't required unless you want to have it plug into the *e7* standard engine bay fuse/relay box (i know there is a spot for it, but not sure if the wiring is there like an 86 one). All the efi main relay does is give a 12v ignition source and power the ecu, the fuel pump and possibly one or two other items (probably on later model 4a's). I usually use the black orange wire (coil/igniter power) to trigger a new relay and create a new 12v iginition source (and label it efi main). Another: The COR is supposed to draw its power from the EFI main relay (there is no seperate fuel pump fuse). The EFI main relay will be switched by IGN connected by a 15amp fuse to the battery. The EFI main relay also powers the ECU and TVIS actuator. I'm just confused. someone care to help or draw me a diagram to follow?
  10. If it is sorted care to share?
  11. Car looks great, where do you source your TRD gear from? I'm looking to build my AE71 very similarly
  12. I really think you are wasting your time going for the stretched look, good luck going around corners in the wet as well lol Just go for a normal sized tyre and save up for something else. We will still think your illest don't worry
  13. I think the OP has to make an official decision on what car he wants. You can set up a car for both but you also have to think of where you are going to race the car and where your going to drift it. Is it going to be street registered? What are the regs of the class you want to race in etc If its not going to be street registered do you have a trailer and a tow car to take it there? Have you raced before?
  14. What about normal karts?
  15. really, just don't waste your time. if it was a good way to turbocharge an engine you would see it alot more if you mount your turbo low with a box/heatshield and drive normally noone will know. where will you put the rear turbo anyway?
  16. Those shifters are cheap shit and I would not recommend buying them.
  17. Just bringing this back up from the depths, still havent found the time to take the engine out yet, but will most probably be getting into it during my 4 week break
  18. still own it, 180sx type x
  19. so do you guys think it is not worth building an AE71 for this class? i have a spare car sitting around atm that needs a new engine anyway
  20. was there any mention of what car you have?
  21. First, I think you should work on your grammer lol would make it alot easier to read! Secondly, I don't think that AE86 brakes would be enough to make it legal. What you could look for is AE86 coilovers then do a brake upgrade to those
  22. I would rather stock springs rather than HSD, and save up for some decent coilovers As asked above, it would be good if we knew what car you have
  23. yea do the swap! or rebuild the 5k then do the swap
  24. damn that engine looks good!
