1821 -
17
Everything posted by GJM85
how long is a piece of string? -twice half its length.
Too start off this post i'd like to give a big thanks to Rockinrolla..... Good advice = Money saved. Running with a 4k head and rocker assembly now using the 5k valve springs. Lower compression for an engine that would of ended up with a 20,000,000:1 compression ratio.... Again, another disorientating day. The intake manifold I pulled off the 4k from the 20 is a 3kb manifold. Which got me all tingly inside. I pulled the 5k head down and found the #4 intake valve is bent and all the exaust valves are in pretty bad shape... I had the head and manifold in the car ready too go to the shop tomorrow. Now i'm goin with the 4k head so tomorrow i'll pull one down.... I got a call from MSR Kustoms about the ke20. They've done the arse end neat and straight with a new valence panel and started on the sides. They blew back around the weather channels and they just.... fell off.... :D They've asked me too come in tomorrow and assess the situation. I'm upset now because it's becoming easier and easier too ditch the ke20 and run with the ke55 I got for donor parts..... :D ;) ;) I have reached a critical and pivotal point in the build process.... the 20 has already touched my soul. Here the pix....
I'd like to see a 13-14 out of my ke20 when she's ready. Never know as its the first k motor i've every really built from top to bottom....
Went down to Beenleigh Bearings today. They made some phone calls and confirmed with me that I can use 202 red motor lifters with the standard pushrods and 4k rocker gear. So they on order along with the full rebuild kit included ACL pistons and molly rings. Woot Woot. Should be able to pick up the lot on Friday arvo.
I agree. I just changed the intake on my TS Astra. Now it's full race.
If new cars were poo, I'd be a car dealer.....
No news.... when I went in there yesterday it was pushed into the backyard with all the panels laying around..... I guess because it's not V8 or American its the back burner. I bet they think i'm not good for doi....
well I bid you good luck....
The blacktop 20v is the top of the line 4A motor.fine tuned to the max... in reality, without a large amount of funding there isn't a great deal of room for improvement with the blacktop. The charged 16v which is the small port 4agze will be a much more effective unit with a greater range of improvement. I said it from the beginning.. It will eat a 20v in the low end..... Then if you decide to go a turbs.... with a good EMS, you can boost a standard motor into the 12-13's.
t18'S are like steve irwin's farts... history. Nobody make nothing for them. Make it fit will need to be your middle name! See what Triev did with the ducktail..... that's you.
well I gave my old 92 a pretty good port job.... so... we'll see closer to the head date. Either way.....the flow I want will be...MASSIVE!!!!
well I did an assessment today on the block and lower end gear. The pistons are good, i'd estimate they have done no more than 20,000km and they are ACL's. So as it stands the bottom end will go back together with a full bearing kit and a set of quality rings. From ou measurements the bore stands at 80.55mm and the pistons are clean other than the carbon build up on top, so no it won't be a full rebuild. I priced thhe rebuild kit today and it's around 570$. To get the head reconned with a port and polish i'm looking at $200-$500 for recon and $106/hr for the port job, so I'm probably just going to get it milled 10thou", buy some di-grinder bits, port it myself and put and VRS kit through it. I picked the 5k up from Southport Autorecyclers and it's come with new leads, oil filter, plugs and plug sleeves. THe dizzy looks clean and the cam and lifters have no wear. The waterpump and all bearings look clean as, so I'd say it's been rebuilt recently. There isn't even any corrosion in the water jackets. The ke55, I bought as a doner has made me all confused and discruntled. So far, everyone who has seen it has told me i'ts too good to part. I have too admit. It's totally grannyspec and orginal. It just needs some panel work but other than that she's sweet. It even kicks over first turn. Runs smoothly, quiet and with no smoke until it starts valve bouncing.... oh sweet JESUS!!!!! I feel like a murderer. I'm gonna need a couple of days think this over.... Did the block today, so here's some picks....
There was a lot of weighing up to be done. I originally wanted to run twin webbers but i want a bit more power again. The natural option, turbo or charger came up and this is where the decision was made. There is a lot more involved in turboing. 1) It must be a blow through set up or your risking a lot. 2)It cost a whole lot more in parts. ie. turbo, intercooler, plumbing & modifications etc.... Yes the possibility for a lot more power in the top end is there, but who really needs it on the street? You can't use it to its potential with out losing your license. So the blower was my choice for a number of reasons. 1) its an easy swap from NA to charger with substantial gain of power. 2)The charger as has a clutch and can be turned on and off. 3)More low end power. 4)Far more cost efffective and easy to set up. The list could go on.... but the real reason is I can remove the blower, if I want and still have a fair degree of power.
I would say its an ae82 sedan..... unless its a later '87 model it could be a ae90....
kesev... and a 87 corolla I believe would be an ae8# fwd
Just a request in regards to image uploads. Possibly need the ability to upload mutiply photos at once or the ability to edit the uploaded images on a submitted post. Just did a post in my build thread and it ended pretty badly with a double up and a wrong image. Maybe we already can edit the images.... I just don't know how.
each too there own Akon, each to there own.... Don't let the opinion of others dictate the decisions you make.... unless you plan on rape/pillage/plunder. But yes, sex is in the back seat, rice is on the boot.
Unfortunately in Sunny Bank english is a thing of the past.
Another productive day. I ran the front quarters down to MSR Kustoms. They haven't started the 20 yet.... :D Then when I got home I called the tow guy and organised to get the 55 donor down from Caboolture. Low & behold he was flat today, so he headed up to get it. In the mean time, brother Keiron, who might I add is not a toyota fan hepled me with the 5k. We pulled it down to a block in 2&1/2 hrs. So a few discoveries toay, the '3k' I pulled out of the 20 originally is actually a 4k with all the 3k gear on it & the 5k does not have solid lifters. So from the information I gathered, correct me if i'm wrong but, if I use 202 red motor lifters and datsun 1200 pushrods with the 4k adjustable rocker gear I should get away with it. I'm not entirely sure if a cam and machined head will upset that mix???? Finally as we were packing up the donor arrived and we had a few minutes to give it a quick look over before the missus called stamping her feet. It's obiously been used in a homegrown motorkhana but it's still pretty good. Not running due to a missing negative terminal. It's going to be difficult to take it to pieces. It'll be like a heart donation out of a live patient.... Here's some progress pics. Cheers. PS. It gets hard to keep track of mulitple photo uploads.... the rocker gear photo with the red ignition leads is actually of brother JP's 4k when I was comparing rocker assembly.
School holidays, loss of license... all to familiar for you ain't it, JP? :D
No worries bro, the engine stand hardly left a mark when we assembled it on your bonnet. :P
The 20 went into MSR Kustoms this morning. They looked over it. They think it shouldn't be too much trouble. They're going to cut and fix all the rust and straighten the body and get back to me too see where we're at. Not sure if my budget of $5000 is going to see me through panel and paint though now as they reckon it'll be at least 2k in rust work. It will come down to how many hours they put into it. :| On the way home I stopped in at SuperCheap and picked up an engine stand. I forgot to put the front quarters in the car when it got towed so i'll have to run them up tomorrow morning. :bash: In the mean time I hired a ute from BlowJobs Car and Ute hire and it cost me too much for the measely 6hrs I had it. Still, I got down to Southport Auto Recyclers and picked up the 5k. Looks pretty clean and sweet. The clutch is shagged and it's worn a lot on the flywheel. She still turns over easily with the breakerbar. Brother Keiron and I tried to get the thing on the engine stand but realised some of the gearbox bolts from the 3k have been nicked. :( Turns out they were too short any way, so I had to go to the bolt shop and grab some longer ones. $30 for 4 bolts!!! :P Apparently metric fine threads aren't cheap. :D Anyhow, ran out of time as I had to take the ute back and it's unlikely i'll be able to get into the 5k tomorrow as there's no one available to assist me. Will hopefully get into it on Wednesday! Here's some picks of the new donk
Woot Woot! Just won an sc12 off ebay. Boost, I say! Hopefully get the 5k picked up this week and i'll start the rebuild while the 20 is the shop. The problems, i'm sure, will become evident whilst I try and put this all back together.
yeah guys shut up about awesomely footy sick 20!
that interior is dope! I bet the driver is tom cruises stunt double in top gun!
