My Wifes 4wd 4age & My 4wd 4k
My wifes car
I brought My wife a Sierra for her birthday and she loves it. Bit of a mall cruiser but that will soon change. Dam it I love that 4AGE, ive gotta get one for me now!
* Toyota 4AGE Twin Cam Engine
* Toyota T5 5 Speed
* Micro Tech Computer
* Fully Engineered
* Surge Tank
* Extractors
* Top & bottom end Rebuilt Motor, 500k's ago
* 2" Lift Kit
* 31 x 10.5 Mud Tires
* Tinted Windows
* New roof lining, door trims and carpet.
Planned mods,
* 2" Body Lift
* OME 2" Springs
* It still has 1L diffs, Ill wait and see how they hold up but ive got some 1.3L NTs in the corner.
* Gotta Cut the front bar off and beat all the seams flat, the tyres scrub turning around on flat ground at half lock.
* Gotta get a new steering wheel, not keen on the 1L wheel.
While her zook may be more capable on road mine is a whole lot more capable offroad.
My 4K Sierra
4k toyota donk & 5 speed
95" wheel base
31x10.5 rubber on 15x8 rims
92 WT diffs
5.125 Vit gears
3" Sus lift + Spring over.
2" Body lift
Was hard top, cut to single cab
3/4 elipic rear sus
Custom front bar & tray
Currently being rebuilt.
more info & pics in members section (aerenandmel user name) at http://www.outerlimits4x4.com/index.php
Sweet rides mate! love the fact that you're smiling with the sierra on its side against the bank :hmm: Awesome stuff! :)
great stuff mate, i guy i know had a 4age in his suzuki but i think it was a little bit too much power for it so he ended up chucking a 3k in it, i went and looked at an LJ80 last week with a 4k in it, these little things will go anywere
keep up the good work
aaah goody... you're someone I need to talk to! Whats the deal with the compatibilty of the sierra gearbox to the toyota engines? I know the're very similar, maybe a shared toyota/suzuki design... I've got bits and pieces of info but nothing concrete... are custom bellhousings or adaptor plates required?
Also... (sorry to hit you with the 20 questions) do you know much about the similarities of the sierra to the AL25 tercel running gear? ie: transfer case and g/box, front cvs etc etc...
Cheers heaps in advance
What's the deal with the compatibility of the sierra gearbox to the toyota engines?
They don't bolt up but ive herd you can get a custom bellhousing, but there really rare, the company didn't make them for very long. Ive got a k5 behind the 4k & a t5 sprinter box behind the 4AGE. I don't think the Sierra box would last long behind the 4age, probably go bang...loudly. I just pulled the K5 down to put some new seals & bearings in him and found the hardening on the cluster & shaft is stuffed. Its an older k5 with only the reverse light switch in it. Ive got a k5 from a ke70 for it but the shifter is in a different spot and the mounts are different. look like ill be making a new crossmember again. The newer one might be stonger, I don't know yet. I'm told its the same length and will bolt up to the 4k the same apart from the mounts.
not sure if there is any. aren't they an east west engine? the sierra has an independent transfer case, its not attached to the gear box. there is a short drive shaft (called a jack shaft) from the gear box to the transfer case. the sierra has a live axle in the front, lick a rear diff but with swivel hubs with cv's inside them . I don't know, but Id imagine the tercel has an independent front end?
Hope I answered your questions at least a little bit, or maybe I just confused you more. I don't know much about tercel in case you were wondering.
Sweet rides mate! love the fact that you're smiling with the sierra on its side against the bank :lolcry: Awesome stuff! :yes:
Me & the boys have a carnage points system :hmm: were you earn points for trail carnage/rockrash when its done by accident while attempting the near impossible. As he old sayen goes, “rollen and beers†:)
wicked stuff mate, oh and the gearboxes are t50's and k50's rather than t5/k5
love the stealthy white sierra! well done on your conversion!
Yeah thats cool thanks for the info... the early tercels had a north-south A series engine and a separate transfer case with equal length front cvs. full time fwd and selectable 4wd, with the rear live axle diff permanantly locked. really weird setup.
I just asked cos there's a bit of a cult following for the tercel in france, and they seem to use a lot of sierra gear. most of the info is too hard to translate though.
cheers anyway mate... guess I'll just shoehorn the 4age in and see what breaks first :hmm:
they wouldnt happen to have low range in the transfer case?
My housemate has a heavily modified bigport in a sierra, what can I say it makes a lethal combination. His diffs last a few years. The transfer case will break first.
Swap the extension housing from the 5 speed you just pulled out onto the KE70 5 speed, and it will bolt straight back in :) I have done this myself on many occasions.
The KE70 gearbox will bolt onto the engine identically to the older 5 speed you have
was it a blue one? i think i may know the fella that built it!
